Más abajo en ESPAÑOL
Hi, I’m a mikrotik user several years ago and this never happened to me. I tell you my problem.
I have MANTBOX APs and I permanently have clients that are associated with the AP but only in layer 2.
The CPEs work in ROUTER mode and are assigned fixed IP each.
It usually happens that X amount of cpe are associated but the AP does not see its IP, only its MAC. That client claims not to have service.
I ping the CPE ip and it does not respond. With MAC PING there is a response and generally after a moment of running MAC PING, the AP recognizes the IP of the Client.
There are cases in which it is not enough, and I must enter by MAC TELNET, and there the AP only recognizes the client’s IP.
Has anyone happened to you?
Thanks since now.
regards
MARCELOTE
Hola, soy usuario de mikrotik hace varios años y nunca me pasó esto. Les comento mi problema.
Tengo APs MANTBOX y permanentemente tengo clientes que se asocian al AP pero solo en capa 2.
Los CPE trabajan en modo ROUTER y tienen asignada IP fija cada uno.
Suele ocurrir que X cantidad de cpe estan asociados pero el AP no ve su IP, solo su MAC. Ese cliente reclama no tener servicio.
Hago ping a la ip del CPE y no responde. Con MAC PING hay respuesta y generalmente despues de un instante de ejecutar MAC PING, el AP reconoce la IP del Cliente.
Hay casos en los que no es suficiente, y debo ingresar por MAC TELNET, y allí recién el AP reconoce IP del cliente.
¿A alguien le ha pasado?
Gracias desde ya.
Saludos
MARCELOTE
