Hello.
I need replace very old AP (TL-WA500G -WiFi g), which has connected some directional look-like external antena and placed in almost corner of steel hall for an authorized car service use (diagnose, programming firmwares…).
It is about 360m2 (18mx20m) and old AP was doing good but in about 1/2-3/4 of area,
Old AP is having some problems and does not meet the speed requirements for car servicing anymore which is understandable.?
I was asking for money to replace this AP from moment i started working with this company and i wont to change for device which will be 100% suitable probably for next 15 years
I chose NetMetal ac2 + 2x HGO-ANTENNA-OUT.
Can somebody tell me if this is right hardware or should i choose for example another antena with better gain, different radiation (needed more than 90 degree wide) or completely different AP? If yes, then please tell me why so i can learn more about this mikrotik devices.
