I have 2 MKTs in NETWORK. 1-st is used as firewall, VPN, DHCP etc. / 2-nd I want to use as only a wifi router together with POE (ON WAN port) with LAN static IP xx.xx.88.2
If I connect LAN cable from switch to ETH2 (LAN), power adapter is used in this case, everything is working fine. Like normal AP Wifi router (DHCP is on 88.1).
Same way I nee to do it on WAN port, because there is a possibility of POE.
I hope I explained it well.
MKT: RB-951G
Is there any way how to do it? Bridging?
Thanks for help
Jiri
