AP IPs not visible anymore once VLAN filtering enabled
hello,
Attached is the configuration that I am running on a CRS256, all the VLANs are working properly and they can navigate to internet via the WAN interface.
The APs are TPlink EAP where I created 3 SSID with relateive VLANs, I can connect to each SSID and get the right IP from the DHCP and navigate to intenret.
The problem is that I cannot find and then connect to the AP itself anymore, when I connect to any of these SSID I only see the other devices connected IPs, and from all these VLANs I can only connect to the default gw on WAN interface.
How can I reach the AP itself?
thanks
# software id = SYV6-G9YK
# model = CRS326-24G-2S+
# serial number = XXXXX
add admin-mac=18:FD:74:E6:30:30 auto-mac=no comment=defconf ingress-filtering=\
    no name=bridge vlan-filtering=yes
set [ find default-name=sfp-sfpplus1 ] disabled=yes
set [ find default-name=sfp-sfpplus2 ] disabled=yes
/interface vlan
add interface=bridge name=VLAN-Guest vlan-id=10
add interface=bridge name=VLAN-Home vlan-id=20
add interface=bridge name=VLAN-IOT vlan-id=30
add interface=bridge name=VLAN-TVCC vlan-id=40
add name=WAN
add name=LAN
/ip hotspot profile
add name=Guest_pool ranges=10.0.10.2-10.0.10.254
add name=IOT_pool ranges=10.0.30.2-10.0.30.254
add name=Home_pool ranges=10.0.20.2-10.0.20.254
add name=TVCC_pool ranges=10.0.40.2-10.0.40.254
add address-pool=Guest_pool interface=VLAN-Guest name=Guest_DHCP
add address-pool=IOT_pool interface=VLAN-IOT name=IOT_DHCP
add address-pool=Home_pool interface=VLAN-Home name=Home_DHCP
add address-pool=TVCC_pool interface=VLAN-TVCC name=TVCC_DHCP
/port
set 0 name=serial0
add bridge=bridge comment=defconf disabled=yes interface=ether1
add bridge=bridge comment=defconf interface=ether3 pvid=20
add bridge=bridge comment=defconf interface=ether6
add bridge=bridge comment=defconf interface=ether7
add bridge=bridge comment=defconf interface=ether8
add bridge=bridge comment=defconf interface=ether9
add bridge=bridge comment=defconf interface=ether10
add bridge=bridge comment=defconf interface=ether11
add bridge=bridge comment=defconf interface=ether12
add bridge=bridge comment=defconf interface=ether13
add bridge=bridge comment=defconf interface=ether14
add bridge=bridge comment=defconf interface=ether15
add bridge=bridge comment=defconf interface=ether16
add bridge=bridge comment=defconf interface=ether17 pvid=40
add bridge=bridge comment=defconf interface=ether18 pvid=40
add bridge=bridge comment=defconf interface=ether19
add bridge=bridge comment=defconf interface=ether20
add bridge=bridge comment=defconf interface=ether21
add bridge=bridge comment=defconf interface=ether22
add bridge=bridge comment=defconf interface=ether23
add bridge=bridge comment=defconf interface=ether24
add bridge=bridge comment=defconf disabled=yes interface=sfp-sfpplus1
add bridge=bridge comment=defconf disabled=yes interface=sfp-sfpplus2
/interface bridge vlan
add bridge=bridge tagged=bridge,ether2 vlan-ids=10
add bridge=bridge tagged=bridge,ether2 vlan-ids=30
add bridge=bridge tagged=bridge,ether2 untagged=ether3 vlan-ids=20
add bridge=bridge tagged=bridge untagged=ether17,ether18 vlan-ids=40
/interface detect-internet
set detect-interface-list=all internet-interface-list=all lan-interface-list=\
    all wan-interface-list=all
add interface=bridge list=LAN
add interface=ether1 list=WAN
add address=192.168.88.1/24 comment=defconf disabled=yes interface=bridge \
    network=192.168.88.0
add address=10.0.10.1/24 interface=VLAN-Guest network=10.0.10.0
add address=10.0.30.1/24 interface=VLAN-IOT network=10.0.30.0
add address=10.0.20.1/24 interface=VLAN-Home network=10.0.20.0
add address=10.0.40.1/24 interface=VLAN-TVCC network=10.0.40.0
add address=10.0.10.0/24 dns-server=8.8.8.8 gateway=10.0.10.1
add address=10.0.20.0/24 dns-server=8.8.8.8 gateway=10.0.20.1
add address=10.0.30.0/24 dns-server=8.8.8.8 gateway=10.0.30.1
add address=10.0.40.0/24 dns-server=8.8.8.8 gateway=10.0.40.1
set servers=8.8.8.8
/ip firewall address-list
add address=192.168.1.14 list=WAN-whitelist
add action=accept chain=input connection-state=established,related,untracked
add action=drop chain=input in-interface-list=!LAN
add action=accept chain=forward ipsec-policy=in,ipsec
add action=accept chain=forward ipsec-policy=out,ipsec
add action=fasttrack-connection chain=forward connection-state=\
    established,related hw-offload=yes
add action=accept chain=forward connection-state=established,related,untracked
add action=masquerade chain=srcnat ipsec-policy=out,none out-interface-list=WAN
/system clock
set time-zone-name=Europe/Rome
/system identity
set name=MTHome
/system note
set show-at-login=no
/system ntp client servers
add address=time.google.com
/system routerboard settings
set boot-os=router-os
Most likely something wrong on the setting of the AP itself or VLAN settings for default id=1.
Is the AP set to connect to that specific VLAN ? I assume most can not.
So …
How do you treat devices belonging to VLAN 1 (= default VLAN) ? As far as I can tell, you do not ? You do something with 10 / 20 / 30 / 40 but nothing for 1.
I am not sure if I get yout reply.
I configured 3 SSID on the AP SSID1->vlanid 10, SSID2->vlanid 20 and SSID3->vlanid 30, if I connect to each of these SSID I will get the correct IP in the right VLAN, I did not configured vlan1, should I on the AP? how exactly, on EAP I can set VLANs only on the SSID if I am not wrong.
My point:
you did set the VLAN Ids for the SSIDs on AP and router and that works, perfect.
But your AP itself also needs to communicate. It is also a device somewhere on the network.
Is it VLAN Aware (the device itself) ? If not, it will most likely communicate using default vlan id which is 1 (if it is not set, all ethernet frames will have at least ID=1).
But your setup has nothing for vlan=1, so no communication.
I assume looking at your config your APs are connected to ether 2 (since all other VLANs also come there)?
What you could try is to set a separate mgmt VLAN on ether2 with untagged for that id. So everything which comes in on ether2 with default tag = 1 will be put on that mgmt-VLAN.
And then set router services for that VLAN as you did for the others.
On the router side (since it is Mikrotik) a lot of people here will be able to help.
On the AP side, that’s a bit less (for logical reasons. This is not a TP LINK forum).
got it.
So on the AP I enabled the management VLAN that is 1.
But I see that in the MT router the bridge vlan list the vlan 1 is created dynalically and the ether2 is already untagged there, but still I can’t see the AP. Is this dynalyc entry in the list something that I can configure or I have to assume that as is?
Specify it manually, add bridge as well as tagged.
Dynamic entry will disappear.
ok, I did:
on AP set the VLAN 99 for management (instead of 1)
on MT:
  1. created the VLAN 99, with all settings (dhcp, network, ip, etc)
  2. used pvid 99 on port ether10
  3. added vlan 99 in the bridge vlan list with bridge tagged and ether2 untagged
I connected a device directly on port ether10, the device is able to get the IP in the 99 network, but still don’t see the AP
Timeout … what ports do those APs connect to on your router ?
And how did you create that VLAN interface ? On an ether port ?
the AP is connected to the ether2 and I created the vlan99 on bridge
add admin-mac=18:FD:74:E6:30:30 auto-mac=no comment=defconf \
    ingress-filtering=no name=bridge vlan-filtering=yes
/interface vlan
add interface=bridge name=VLAN-MNGMT vlan-id=99
add name=WAN
add name=LAN
/ip hotspot profile
add name=MNGMT_pool ranges=10.0.99.2-10.0.99.254
add address-pool=MNGMT_pool interface=VLAN-MNGMT name=MNGMT_DHCP
/port
set 0 name=serial0
add bridge=bridge comment=defconf interface=ether10 pvid=99
add bridge=bridge tagged=bridge untagged=ether2 vlan-ids=99
add address=10.0.99.1/24 interface=VLAN-MNGMT network=10.0.99.0
add address=10.0.99.0/24 dns-server=8.8.8.8 gateway=10.0.99.1
set servers=8.8.8.8
add action=accept chain=forward connection-state=\
add action=masquerade chain=srcnat ipsec-policy=out,none out-interface-list=\
    WAN
/system clock
/system identity
set name=MTHome
/system note
What do you mean with “I don’t see the AP” ?
Is that AP configured for DHCP or does it use a set IP address ? If the latter and the IP range is not within scope for any of your VLANs, then nothing will happen.
Have you used tool/torch to check what’s happening on ether2 ?
Also, if you connect your PC on ether2, does it get an IP address ? Can you reach gateway for VLAN99 that way ?
yes! Correct, the dhcp was set on the old subnet, because the tpink configuration interface needs to save on each page, so if I do a change on a page and without saving switch on another I lost the change.
thank you for the hits.
Sweet !
Glad it works now.
