AP load balancing.
Is there future in Mikrotik - AP load balancing?
I have mt with 3 wifi cards + 3 antena at the similar direcitons (the same ssid), and I would that custumer connect to the card, which is no so much loader. For now on the card I have for example 3 clients, next card 4 clients and last card has 40.
Is there any solution?
Greetings
raqu
Maybe you could reduce the TX power on the more popular AP interface thereby forcing the clients onto the other interfaces…
Would be very interested on how you get on.
raqu,
can you pls explain how did you configured your AP to use same ssid … 3 different channels or wds ?
I’m interested to do the same …
thank’s
Besim
