Hello everyone,
I’m facing a speed issue with my access point. When I configure a static IP, the connection speed drops significantly to 2.5 Mbps, but when I use DHCP, it reaches around 90 Mbps. Below is my current configuration:
add name=WIRELESS
add name=bridge1
add authentication-types=wpa2-psk mode=dynamic-keys name=DEFAULT1 \
supplicant-identity="" wpa2-pre-shared-key=Ex5pqrfn!
/interface wireless
set [ find default-name=wlan1 ] country=italy disabled=no mode=ap-bridge \
security-profile=DEFAULT1 ssid=WIFI_test
set [ find default-name=wlan2 ] disabled=no mode=ap-bridge security-profile=\
DEFAULT1 ssid=MikroTik
/ip hotspot profile
add name=dhcp_pool0 ranges=10.2.2.2-10.2.2.254
add address-pool=dhcp_pool0 disabled=no interface=WIRELESS name=dhcp1
add bridge=WIRELESS interface=wlan1
add bridge=WIRELESS interface=wlan2
add address=192.168.149.251/24 interface=bridge1 network=192.168.149.0
add address=10.2.2.1/24 interface=WIRELESS network=10.2.2.0
add address=10.2.2.0/24 gateway=10.2.2.1
set servers=192.168.141.41,192.168.141.42
add distance=1 gateway=192.168.149.1
Any suggestions on why the static IP would be so much slower? Could this be related to the NAT rule or some other configuration I’m overlooking?
Thanks in advance for any advice or insights!
