Здравствуйте,
тестировал AP Sync в последней версии 6.40rc41, не понравилось как работает.
На AP стоит sync master (к нему подключаются клиенты), затем поставил на QRT5 sync slave точка- точка (15км), скорость на релейке упала в разы. Где копать?
И другой вопрос. Как сделать Sync на AP куда уже приходит типа Sync релейка. Получается что новая AP должна как то синхронизироваться с релейкой точка-точка.
Tested AP Sync in the latest version 6.40rc41, did not like how it works.
On the AP is sync master (clients are connected to it), then put on the QRT5 sync slave point-point (15km), the speed fell at times. Where is the mistake?
And another question. How to make Sync on AP where the point-to-point Sync already comes. It turns out that the new AP should be synchronized with point-to-point sync slave.
QRT must be AP and then only works if the QRT5 is on the same frequency as the AP on that tower. Not worth it unless you have no channels left at all.
There is no sync for AP’s on other different channels and there is no sync over Ethernet subnet.
There isn’t even Sync for cards in the SAME router board - which you would think would be relatively easy to do!!! Still Mikrotik ignores what all of us beg for every week - we need Sync. We need Sync yesterday!
I ripped out another 24 RB411’s and 2 x RB433AH’s this month and replaced them with a vendor that actually cares about wireless, and supports sync. I’ve been deploying Mikrotik wireless since 2008 !!! Hundreds of thousands of dollars… this is so pathetic.
