Hi, some my clients have bad signal and when there is the worsening of weather, they cause other clients connected to the same card big raise in ping. I want them not to connect if they have bad ccq, or throughoutput. I found in wireless registration table ap tx limit and client tx limit - can be that used, what does it mean and what does it do? Can you help? Thanks
hello, you can select signal strength range in ap access list , if you want to disconnect wireless connection of that client remove both ticks of authontication and forwarding
I know that, but I dont know what mean ap tx and client tx limit, under circle you made.
AP tx Limit and Client tx Limit == datarates ( bandwidth for Client )
What values are accepted here? Is it the best way to limit the bandwidth used by each radio?
