AP-TX-limit with new wifi
Is there any equivalent to the old wireless AP-TX-limit for the new wifi-qcom or wifi-mediatek, specifically using the new wifi capsman?
I have a situation where I need to implement per client device TX limits on the AP and anything queue based is both very overkill, and also extremely impractical since the limit needs to be per virtual AP, with different limits per virtual AP. Client upload limiting isn't needed here. The old wireless AP-TX-limit setting would perfectly fit what I need here, But I can't locate documentation showing there's still an equivalent setting.
RADIUS -> Mikrotik-Rate-Limit ??
Non-radius application otherwise I would have tried that, but good suggestion nonetheless, should have mentioned it wasn't using radius.
