good day every one here i instail 5 ap as wds all of then having the same configuration, i discover that when i put on one of the five the return time will increse and some thing the Ap that leads to the gateway will time out.
Please what could the problem be can any one here help?
thanks
yup..
when you will set roaming [wds] as AP2AP you have to set
same: ssid, band, frequency, and create correct wds address than put ip address for manage your networks, all ap must support wds ofcourse...
regards
Hasbullah.com
yes i did and i add address on the bridge interface
the first AP is 192.168.0.1/24 192.168.0.2/24 192.168.0.3/24 192.168.0.4/24 192.168.0.5/24 and and using dynamic wds,did i still need to set wds address address when using dynamic?
Thanks for your reply.
as far as i used, static wds for my networks until now, and great...
my roaming set AP2AP Mikrotik's and Non Mikrotik's divices. and set to transparant netwoks for far far way.
