AP WDS..to HOW MANY Clients
Hi All,
I have MT AP With WDS in my WIFI Network.
How many Laptop can connect at a Time with 64 Kbps speed individually.
Its Single Hall( Medium size) and my AP is installed in the central.
Just i want to know the capacity, HOW MANY CLIENTS CAN CONNECT TO SINGLE AP.
Well IN A medium single HALL you WILL HAVE about ((HALL-SQM/2Mbit*Teraflop)/19) USERS. OR YOU COULD STOP SHOUTING AND START READ THE FORUM POSTS ABOUT THIS.
/Henrik
real useful diganet, thanks… he was prob. trying to stress his actual question…
anyway, if all your clients will have line of sight with the AP antenna, (like people gathered in a hall, sitting at tables, no walls) and you are using something with more RAM than a RB 112 (i.e. a 59$ 133 !!!) and a good radio (r52, cm9, sr2). I would say ~40-50 users…maybe more…are they all going to be streaming something @ 64k? or like surfing the web? if streaming some one else will have to chime in with input…web browsing and short burst type usage should be fine, and with much more than 64k per user…
EDIT: crap..just read the WDS part…does that mean this is a repeater?? if so then you could certanly have issues @30 ppl…what type of equip is the MASTER of the Repeater? RSSI? S/N?
