I think 3 omni’s can get messy. If you have overcrowding and interference; you might try horizontal sectors. And if your CPE’s support the feature, use narrow channels. Narrow channels will greatly help to mitigate interference.
The problem is we already have 50~70 clients connected to this AP, then switch to horizontal will become difficult.
And I see no advantage in switching to horizontal because the interferece is also large.
In addition, our CPEs do not support this function that you mentioned.
CPEs are cheap with limited resources.
I second jp’s suggestion.
I have an RB600 with 3 XR2s and 3 sectorials. Great coverage.
3 omnis coming out of that one unit, even 3 omnis on one mast! Unthinkable.
In our case, it would be interesting customers migrate sector automatically in case of interference. And in some regions there are large number of customers and in others not. If I used panels, 1 or 2 would be overcrowded and others without customers.
What I can not understand is why, technically, I can not make this installation method?
The idea is that it has 3 frequencies radiating in all directions in non-ovelapping channels, then we can have greater amount of subscribers and a choice of 3 channels to work.
Will use the same SSID in all sectors; rules will be added in the “Access list” that will limit customers to connect if the signal less than -75; and will limit the max-station-count = 35.
