I’ve been reading and reading but this should be my first post… I’m new to Mikrotik hardware - but so far, I’m very pleased with how much control we have with them - better than many I’ve paid a lot more money for. I’ve worked a lot with Netgear SOHO, and Cisco and HP enterprise equipment over the years.
That said, I’m trying to use one for an install at an apartment complex - it’s an RB450G; It’ll be connected to 8 Ubiquiti UAP-LR Unifi Access points. Since it only has 5 ports, I’ll have to add a switch - most likely it’ll be a netgear 8-port smart switch (not fully managed but supports VLANs) - because I have one handy and can’t get any ordered parts here in time.
I just have some general questions while I wrap my head around how Mikrotik works… I have no problem searching - I’ll do it all day long; I just need some pointers to help me know what I’m searching for and what concepts to get my head around.
I want to support VLANS - 1 for management; 1 for normal tennant traffic, and one for guests
I want the tenants devices to not be able to see each other (I’d love user-based VLANS but Ubnt/Unifi doesn’t support that yet.
Guest mode has to go through a TOS agreement captive portal first then has limited bandwidth.
Not every AP will be on a port of the RB - some (or all can be) will be on the netgear vlan-aware switch.
Unifi can do some of this - I can do a guest portal and some client isolation, but some of the settings conflict with other, so I either need to ditch the captive portal for guests, or do client isolation elsewhere.
I have read a little about disabling default forward and i’m trying to understand that better… but I wondered if I could get any pointers from you guys.
Any specific solutions or terms I should search for, or posts I should read?
Is that netgear in the middle going to screw up my plans?
Thanks guys! Any help is appreciated; I have to have this figured out this weekend.
