API enable\disable ip sec peer
Hi, could somebody help me with API ?
I need equivalent of cli command
/ip ipsec peer disable peer1
I use php
<?php
require './routeros_api.class.php';
$API = new RouterosAPI();
$API->debug = true;
if ($API->connect('1.1.1.1', 'api', 'api')) {
$API->comm("/ip/ipsec/peer/disable/peer1");
    $API->disconnect();
Connected...
<<< [33] /ip/ipsec/peer/disable/peer1
>>> [5/5] bytes read.
>>> [5, 33]!trap
>>> [24/24] bytes read.
>>> [24, 8]=message=no such command
>>> [5/5] bytes read.
>>> [5, 1]!done
Disconnected...
Please read documentation on how to use API
https://wiki.mikrotik.com/wiki/Manual:API#Command_description
Documentation is not so clear, that why I asked.
Finally it worked
<?php require './routeros_api.class.php'; $API = new RouterosAPI(); $API->debug = true; if ($API->connect('1.1.1.1', 'api', 'pass')) { $API->comm("/ip/ipsec/peer/disable =numbers=peer1"); $API->disconnect(); }
