I recently published my small API library on GitHub
it’s a lightweight, fast and super simple API library for Mikrotik.
https://github.com/janmohammadi/MikrotikDotNet
Nuget:
Install-Package Mikrotik.Net
Simple command with parameters (ExecuteNonQuery):
using (var conn = new MKConnection(IPADDRESS, USERNAME, PASSWORD))
conn.Open();
var cmd = conn.CreateCommand("interface pppoe-client add");
cmd.Parameters.Add("interface", "ether1");
cmd.Parameters.Add("Name", "Test"); // You can use PascalCase or kebab-case in parameter name.
cmd.Parameters.Add("user","Test");
cmd.Parameters.Add("password", "Test");
cmd.ExecuteNonQuery();
Read response: (ExecuteReader):
conn.Open();
var cmd = conn.CreateCommand("ip address print");
var result = cmd.ExecuteReader();
foreach (var line in result)
Console.WriteLine(line);
The result (Raw API response):
!re=.id=*4=address=10.20.1.19/16=network=10.20.0.0=interface=bridge1=actual-interface=bridge1=invalid=false=dynamic=false=disabled=false
!re=.id=*5=address=172.16.0.1/30=network=172.16.0.0=interface=bridge1=actual-interface=bridge1=invalid=false=dynamic=false=disabled=false
!re=.id=*6=address=172.19.1.19/19=network=172.19.0.0=interface=bridge1=actual-interface=bridge1=invalid=false=dynamic=false=disabled=false
To query data at API level:
Filtering at API level decreases network payload and improves the performance.
conn.Open();
var cmd = conn.CreateCommand("ip address print where address=172.16.0.1/30");
Result:
OR:
conn.Open();
var condition = new MKCommandParameterCollection()
new MKCommandParameter("address","172.16.0.1/3"),
new MKCommandParameter("address","172.19.1.19/19")
var result = cmd.ExecuteReader(queryConditions: condition, logic: MKQueryLogicOperators.Or);
Result:
To deserialize response: (ExecuteReader)
class MyIpAddress
public string MKID { get; set; } //MKID alwase referce to .id field in response.
public string Address { get; set; } // Use PascalCase naming style for properties. it will convert from/to kebab-case naming.
public string Interface { get; set; }
conn.Open();
var result = cmd.ExecuteReader<MyIpAddress>();
foreach (var ip in result)
Console.WriteLine($"{ip.MKID} - {ip.Address} - {ip.Interface}");
Result:
*4 - 10.20.1.19/16 - bridge1
*5 - 172.16.0.1/30 - bridge1
*6 - 172.19.1.19/19 - bridge1
Note: Using method ExecuteReader only reads the fields that are present in the given type, using the .proplist field in the query.
To get dynamic object response: (ExecuteReaderDynamic)
you can get response object without defining any model class.
conn.Open();
var result = cmd.ExecuteReaderDynamic();
Console.WriteLine($"{ip.Id} - {ip.Address} - {ip.Interface}"); //MKID switched to Id
Result:
Note: Using method ExecuteReaderDynamic reads all fields from the router it will increase response payload.
Read data from background commands: (ExecuteBackground)
Some commands work in the background ( like ping, bandwidth test, discovery,…)
conn.Open();
var cmd = conn.CreateCommand("ping");
cmd.Parameters.Add("address", "10.20.0.4");
cmd.Parameters.Add("count", "3");
cmd.Parameters.Add("interval", "1");
cmd.ExecuteBackground();
Thread.Sleep(5000);
Console.WriteLine($"{ip.Host} - {ip.Time} - {ip.Ttl}");
Result:
10.20.0.4 - 13ms - 128
10.20.0.4 - 6ms - 128
10.20.0.4 - 4ms - 128
