How to get all available routing tables?
for example - /ping a have routing-table parameter… how i can get it all from API?
thanks!
thanks!
Question is how would you get them from the command line…
I’m guessing “/ip route print”, and then loop over that to find all distinct occurrences of “table”.
Routing tables may exist even if no route is associated with them. e.g. a VRF with no assigned IP address on its interface. Or a mangle rule setting a routing mark.
But there must be an direct method, since they appear in the dropdown lists in winbox.
If not, this is the moment of a feature request ![]()
