Hi everyone,
does anyone have an example to connect to the Java language using Mikrotik?
The example is the wiki I could not implement. Getting the following doubts:
this import is from where?
import api.*;
and this class here I too, of where it is?
T3apiView t3A = null;
I will try to implement an interaction web part that accesses the Web proxy Mikrotik. And the language I chose was java. If someone can help me thank you.
I know this thread is probably dead but in case anyone else stumbles upon it here is what I found.
T3apiView is probably a class that the author of the Mikrotik Java API doc wrote and did not include since it was probably pulled out of a project they were working on. Replace T3apiView with the class name of the source code you are working on.
import api.*;
If you are using the code in the wiki it should be:
import libAPI.*;
That will import all the classes in the libAPI package.
ApiConn, Hasher, ReadCommand, and WriteCommand.
Hopefully this helps someone as I was confused for a while.
