kaza
September 9, 2008, 4:27pm
1
I’m using mikrotik api on mk 3.13… and now I see this error message while connecting to one of the routers:
<<< /login
!trap
=message=cannot get challenge
!done
Other routers are working fine… Problematic one is RB1000 under heavy load, so I will be glad to avoid reboot (it was working on this machine before).
What could be the reason for this failure and how to avoid it/fix it?
Thanks for any hints
kaza
September 9, 2008, 4:59pm
2
After few hours it’s working again.. without reboot / without any change.
<<< /login
!done
=ret=97f6e9ba24d23bc50cc17bdf7f556ef9
<<< /login
<<< =name=xxxxxx
<<< =response=xxxxxx
!done
so is this something I should be worried about?
normis
September 10, 2008, 11:03am
3
You should receive that error only when you have received 100 challanges
(sent in response to first /login command), but have not responded to them
with following /loing command with name & response.
This condition should timeout in 5s.
