Api Mikotik
Hello, I need help from the community. I have a Mikrotik 750, it is factory reset and does not have any firewall programmed. It has API port 8728 enabled. What I need is to communicate with the API through this port and I can’t do it. I configure the api in POSTMAN and to test I do it through port 80 and the connection is correct, but only with the change to port 8728 I no longer have communication. Does anyone know if you have to do any special configuration to access through the API. The Url+ APi is: http://10.10.10.1:8728/rest/ip/address
Rest API is on port 80 / 443 the old api which is completely different, is on port 8728
