hi,
i use node-red dashboard for some reasons.
what command i can use in mikrotik API to check if cable is plugged 10-100-1000 ?
i know in mikrotik terminal this command worked: interface ethernet monitor ether4 once
i also try this command for see error’s in API;
/interface/ethernet/monitor =number=4 =once
/interface/ethernet/monitor/ether4/once
but its not working.
is it “once” work in API command ?
also when i use /interface/ethernet/monitor there is no error in debug
something wrong O-o
