I’m trying to add IP addresses to an address list in firewall using C++
Where I have an issue is in differences between CLI and API syntax
For example I can send a command like “/ip/firewall/address-list/add” and then it returns me an error message “failure: empty list name not allowed” which is fine but I don’t know how to proceed after as I don’t quite understand how do you set arguments?
In CLI an equal string will be:
“/ip/firewall/address-list> add address 192.168.88.100 list AllowedList comment ID-100”
and it works
But I just don’t know or understand the syntax after the last command as ‘/’ delimiter works only up until the actual last command before arguments it seems
I can’t seem to find any good wiki, FAQ or docs on API anywhere - so any help with this example?
