Take it, edit it and use it as you need.
No support.
CLASS
<?php
// RouterOS API class
// Author: Denis Basta
class routeros_api {
var $debug = false; // Show debug information
var $error_no; // Variable for storing connection error number, if any
var $error_str; // Variable for storing connection error text, if any
var $attempts = 5; // Connection attempt count
var $connected = false; // Connection state
var $delay = 3; // Delay between connection attempts in seconds
var $port = 8728; // Port to connect to
var $timeout = 3; // Connection attempt timeout and data read timeout
var $socket; // Variable for storing socket resource
function debug($text) {
if ($this->debug)
echo $text . "\n";
function encode_length($length) {
if ($length < 0x80) {
$length = chr($length);
else
if ($length < 0x4000) {
$length |= 0x8000;
$length = chr( ($length >> 8) & 0xFF) . chr($length & 0xFF);
else
if ($length < 0x200000) {
$length |= 0xC00000;
$length = chr( ($length >> 8) & 0xFF) . chr( ($length >> 8) & 0xFF) . chr($length & 0xFF);
else
if ($length < 0x10000000) {
$length |= 0xE0000000;
$length = chr( ($length >> 8) & 0xFF) . chr( ($length >> 8) & 0xFF) . chr( ($length >> 8) & 0xFF) . chr($length & 0xFF);
else
if ($length >= 0x10000000)
$length = chr(0xF0) . chr( ($length >> 8) & 0xFF) . chr( ($length >> 8) & 0xFF) . chr( ($length >> 8) & 0xFF) . chr($length & 0xFF);
return $length;
function connect($ip, $login, $password) {
for ($ATTEMPT = 1; $ATTEMPT <= $this->attempts; $ATTEMPT++) {
$this->connected = false;
$this->debug('Connection attempt #' . $ATTEMPT . ' to ' . $ip . ':' . $this->port . '...');
if ($this->socket = @fsockopen($ip, $this->port, $this->error_no, $this->error_str, $this->timeout) ) {
socket_set_timeout($this->socket, $this->timeout);
$this->write('/login');
$RESPONSE = $this->read(false);
if ($RESPONSE[0] == '!done') {
if (preg_match_all('/[^=]+/i', $RESPONSE[1], $MATCHES) ) {
if ($MATCHES[0][0] == 'ret' && strlen($MATCHES[0][1]) == 32) {
$this->write('/login', false);
$this->write('=name=' . $login, false);
$this->write('=response=00' . md5(chr(0) . $password . pack('H*', $MATCHES[0][1]) ) );
$this->connected = true;
break;
fclose($this->socket);
sleep($this->delay);
if ($this->connected)
$this->debug('Connected...');
else
$this->debug('Error...');
return $this->connected;
function disconnect() {
$this->debug('Disconnected...');
function parse_response($response) {
if (is_array($response) ) {
$PARSED = array();
$CURRENT = null;
for ($i = 0, $imax = count($response); $i < $imax; $i++) {
if (in_array($response[$i], array('!fatal', '!re', '!trap') ) ) {
if ($response[$i] == '!re')
$CURRENT = &$PARSED[];
else
$CURRENT = &$PARSED[$response[$i]][];
else
if ($response[$i] != '!done') {
if (preg_match_all('/[^=]+/i', $response[$i], $MATCHES) )
$CURRENT[$MATCHES[0][0]] = (isset($MATCHES[0][1]) ? $MATCHES[0][1] : '');
return $PARSED;
else
return array();
function read($parse = true) {
$RESPONSE = array();
while (true) {
$LENGTH = ord(fread($this->socket, 1) );
if ($LENGTH > 0) {
$_ = fread($this->socket, $LENGTH);
$RESPONSE[] = $_;
$STATUS = socket_get_status($this->socket);
if ($LENGTH > 0)
$this->debug('>>> [' . $LENGTH . ', ' . $STATUS['unread_bytes'] . '] ' . $_);
if ( (!$this->connected && !$STATUS['unread_bytes']) || ($this->connected && $_ == '!done' && !$STATUS['unread_bytes']) )
break;
if ($parse)
$RESPONSE = $this->parse_response($RESPONSE);
return $RESPONSE;
function write($command, $param2 = true) {
if ($command) {
fwrite($this->socket, $this->encode_length(strlen($command) ) . $command);
$this->debug('<<< [' . strlen($command) . '] ' . $command);
if (gettype($param2) == 'integer') {
fwrite($this->socket, $this->encode_length(strlen('.tag=' . $param2) ) . '.tag=' . $param2 . chr(0) );
$this->debug('<<< [' . strlen('.tag=' . $param2) . '] .tag=' . $param2);
else
if (gettype($param2) == 'boolean')
fwrite($this->socket, ($param2 ? chr(0) : '') );
return true;
else
return false;
EXAMPLE
<?php
require('routeros_api.class.php');
$API = new routeros_api();
$API->debug = true;
if ($API->connect('111.111.111.111', 'LOGIN', 'PASSWORD')) {
$API->write('/interface/getall');
$READ = $API->read();
$ARRAY = $API->parse_response($READ);
print_r($ARRAY);
$API->disconnect();
OUTPUT
Array
[0] => Array
[.id] => *1
[name] => ether1
[mtu] => 1500
[type] => ether
[running] => yes
[dynamic] => no
[slave] => no
[comment] =>
[disabled] => no
[1] => Array
[.id] => *2
[name] => ether2
[mtu] => 1500
[type] => ether
[running] => yes
[dynamic] => no
[slave] => no
[comment] =>
[disabled] => no
[2] => Array
[.id] => *3
[name] => ether3
[mtu] => 1500
[type] => ether
[running] => yes
[dynamic] => no
[slave] => no
[comment] => ether3
[disabled] => no
routeros_api.class.zip (1.83 KB)
