API Port blocked
Hi all
I need some help, I have a php site which posts some code to my RB’s via the API port. One of my clients has a Fibre connection which they cannot open any ports on, nor are there any free ports.
I was wondering if it is possible for me to run a VPN from my RB to the server which is trying to post the code to the RB and not need port 8291 this way?
As you will notice I am a real novice, any help is much appreciated!
Hello Sigma721,
Yes it is able to do, but only if you are activating the API and set a user and a password for this!
The API is by default not enabled!
