After upgrading routers to 3.24 the api never returns after login, I can see in the log that the api user logged in but the connection just hangs, I have been using this script to monitor wireless connections for long time and the only change was the upgrade to 3.24, It works fine on the routers I have not upgraded. Is anyone else having this problem, or has something change in the api in 3.24 that I missed?
-John
