I have some script who upload stats to webservice. And sometimes script generate trash file (when webservice is unavailable?). Now I have ~35000 files with 0 length on device.
When I try get list of files (by API, Winbox, Terminal) - device has 100% CPU. Memory not enough for all file listening and device goes to reboot
I want to try remove files from API. Maybe I can run ā/files/printā with paging.. max count⦠or something elseā¦
The only loop there is internally from āfindā, which will eventually give out a list of only the IDs of those files, allowing āremoveā to remove them in one fell swoop.
Even if it takes a while to complete, by the end you wonāt have a single empty file left.
A similar thing can be done from the API too, but it would be less efficient, since the list of IDs would need to be sent back and forth between client and router.
