API Sessions do not disappear.
I’m running firmware 4.11 (latest stable on the site). When connecting with API and disconnecting, the API session stays in the active user list. Over time these accumulate, and I have seen crashes when this list gets too big. It was fixed in the past, but it is back again. Also, when viewing in Winbox the VIA field is showing up as “unknown” instead of “api”. Can this be fixed in the next version?
/user active print
Flags: R - radius
 #   WHEN                 NAME                    ADDRESS         VIA
 0   jan/01/1970 19:01:18 gateway                 192.168.3.101   winbox
 1   sep/08/2010 11:49:13 gateway                 10.255.255.254  api
 2   sep/08/2010 11:49:14 gateway                 10.255.255.254  api
 3   sep/08/2010 11:49:20 gateway                 10.255.255.254  api
 4   sep/08/2010 11:49:24 gateway                 10.255.255.254  api
 5   sep/08/2010 11:49:26 gateway                 10.255.255.254  api
 6   sep/08/2010 11:49:28 gateway                 10.255.255.254  api
 7   sep/08/2010 11:49:30 gateway                 10.255.255.254  api
 8   sep/08/2010 11:50:02 apilogin                10.255.255.254  api
 9   sep/08/2010 11:50:03 apilogin                10.255.255.254  api
10   sep/08/2010 11:50:17 apilogin                10.255.255.254  api
11   sep/08/2010 11:50:28 apilogin                10.255.255.254  api
12   sep/08/2010 11:55:03 apilogin                10.255.255.254  api
13   sep/08/2010 11:55:17 apilogin                10.255.255.254  api
14   sep/08/2010 11:55:28 apilogin                10.255.255.254  api
15   sep/08/2010 12:00:03 apilogin                10.255.255.254  api
16   sep/08/2010 12:00:17 apilogin                10.255.255.254  api
17   sep/08/2010 12:00:27 apilogin                10.255.255.254  api
18   sep/08/2010 12:03:02 apilogin                10.255.255.254  api
19   sep/08/2010 12:04:25 gateway                 192.168.3.101   telnet
Thanks.
http://forum.mikrotik.com/t/api-connections-still-dont-disconnect/40251/1
So, we have to wait for v5 to become stable. Nice. :frowning: Is there a timeline on v5 stability? I’m also anxious to see performance of Metarouter if it’s fixed or not in v5.
currently we have RC1 in internal testing, if you are interested, email support.
