Knight
October 24, 2012, 11:15am
1
hi i have a small question about set and remove in api
when i want to remove something i use this code
if ($API->connect("$ip", "$user", "$pass")) {
$API->write('/ppp/active/remove',false);
$API->write("=.id=$id");
$READ = $API->read(false);
$ARRY = $API->parse_response($READ);
$API->disconnect();
here i use " .id " to remove user from ppp/active
my question :
are it’s possible to replace " .id " with other thing like name or address
imean the code will be
$API->write("=name=$name");
$API->disconnect();
or
$API->write("=address=$address");
$API->disconnect();
Yes, but only in menus where the other thing is required to be unique, such as the name of a simple queue in the “/queue/simple” menu, interface name at the “/interface” menu, and a few others I can’t recall. I don’t think “/ppp/active” is one of those menus though.
Knight
November 4, 2012, 1:29pm
3
thanks mr boen
how i can use set with name field in simple queue
i use this code
$API->write('/queue/simple/set',false);
$API->write('=limit-at=10M/10M',false);
$API->write('=max-limit=10M/10M',false);
$API->write('=name=<pppoe-11>');
$ARRAY = $API->parse_response($READ);
$API->disconnect();
but nothing happen
it works when i use id field only
but its to hard to use id because every time i want to edit my simple queues or any thing i must to use print first then i take the id and use it with set, and it take a long time if i have many results
At the “.id” argument (or the equivalent “numbers” argument), use the name itself instead of the ID.
e.g.
$API->write('=numbers=<pppoe-11>');
If you use the “name” argument, that will be considered the new name for a queue that previously had the name specified in “numbers”/“.id”.
