API set wireless mode
I’m trying to make the following work with no luck. I’d like to change the wireless mode from AP to STA etc…
The language used is VB.net
mikrotik.Send(“/interface/wireless/set”)
mikrotik.Send(“=wlan1=”)
mikrotik.Send(“=mode=ap-bridge”)
mikrotik.Send(“.tag=sss”, True)
This returns as “unknown parameter”
Any thoughts?
thanx
I suspect this line:
I think it should be
mikrotik.Send(“=name=wlan1”)
ADD: or I use after getting the id for that interface:
mikrotik.Send(“=.id=xxx”)
Thanx
It says done now, but doesn’t actually change the mode
mk.Send(“/interface/wireless/set”)
mk.Send(“=name=wlan1=”)
mk.Send(“=mode=ap-bridge”)
When I do it from terminal it’s fine
interface wireless set wlan1 mode=ap-bridge
I use the id of the interface. I don’t think the name of the interface will do it, only if you want to change the name of the interface. And you need the id to do that.
mikrotik.Send(“=.id=*xxx”)
Chupaka said this should work in one of his responses to an old post. I haven’t tried it
mikrotik.Send(“=.id=wlan1”)
ADD: And if you use this to change the name of the interface, this will no longer work. You should really stay with the id.
And we have a winner
mk.Send(“=.id=wlan1”)
mk.Send(“.tag=sss”, True)
Thanx
It seems that I will have an Windows mobile and CE winbox clone…
If you plan on staying ‘Winbox Alike’, watch out for this later:
mk.Send(“=name=NewName”)
