API Snooper
Hi, I’m trying to get list of all wireless devices heared by an antenna (need MAC address + signal strength) using API. In Winbox I simply run Snooper and get them all. However when I use API (using C#), it only replies with !re and nothing more. Scan function works fine. Anybody trying to use Snooper via API?
Command:
/interface/wireless/snooper/snoop
=interface=Test
Should I use something like “listen” function? How?
Nobody uses API? :open_mouth:
wrong forum
http://forum.mikrotik.com/viewforum.php?f=9
wrong forum
viewforum.php?f=9
Ok, thank you, I will try my luck there. Thought Snooper is under wireless… since it is used only in wireless.
