Apparent NTP package installation problem on RB750UP
I installed the NTP package on two routers - RB750 & RB750UP.
Before installation, the system menu (in Webfig) on both listed SNTP only.
After installation, the system menu on the RB750 listed NTP Client and NTP Server, and SNTP was gone. But on the RB750UP, NTP Client and NTP Server were missing, and SNTP was still listed, even though the NTP package is listed as installed.
Fairly new to RouterOS. Hoping experts can provide advice as to best course of action to “fix” this and get NTP packages properly installed.
Thanks!
The best way to use winbox
Make sure to empy all caches and cookies, those are usually issues with Webfix that cause things like this.
Thanks for the quick responses.
@plisken - I run Linux and do not use Wine, so Winbox won’t work for me.
@tomaskir - I cleared cache and cookies and it seems to have worked! Thanks for that suggestion.
Wondering if it’s using the same browser to manage multiple RBs that’s the issue due to cookie “conflicts”? If so, seems like a design flaw with Webfig. Anyway, now I’ll know what to do in the future if the problem occurs again. I’m glad it was just a browser problem and not a package installation failure.
