nichky:
Here is the export. Have changed the keys and ssid in the export file.
feb/24/2019 22:43:41 by RouterOS 6.42.6
software id = R5WC-9DBR
model = 951G-2HnD
serial number = 4F43041E5438
set [ find default=yes ] authentication-types="" eap-methods=passthrough
group-ciphers=aes-ccm group-key-update=5m interim-update=0s
management-protection=disabled management-protection-key="" mode=none
mschapv2-password="" mschapv2-username="" name=default
radius-eap-accounting=no radius-mac-accounting=no
radius-mac-authentication=no radius-mac-caching=disabled
radius-mac-format=XX:XX:XX:XX:XX:XX radius-mac-mode=as-username
static-algo-0=none static-algo-1=none static-algo-2=none static-algo-3=
none static-key-0="" static-key-1="" static-key-2="" static-key-3=""
static-sta-private-algo=none static-sta-private-key=""
static-transmit-key=key-0 supplicant-identity=MikroTik tls-certificate=
none tls-mode=no-certificates unicast-ciphers=aes-ccm wpa-pre-shared-key=
"" wpa2-pre-shared-key=""
add authentication-types=wpa-psk,wpa2-psk eap-methods="" group-ciphers=
aes-ccm group-key-update=1h interim-update=0s management-protection=
allowed management-protection-key="" mode=dynamic-keys mschapv2-password=
"" mschapv2-username="" name=wpa-aes radius-eap-accounting=no
radius-mac-accounting=no radius-mac-authentication=no radius-mac-caching=
disabled radius-mac-format=XX:XX:XX:XX:XX:XX radius-mac-mode=as-username
static-transmit-key=key-0 supplicant-identity="" tls-certificate=none
Xxxxx-aa-Yyyyyyy wpa2-pre-shared-key=Xxxxx-aa-Yyyyyyy
add authentication-types=wpa-psk eap-methods="" group-ciphers=aes-ccm
group-key-update=5m interim-update=0s management-protection=allowed
management-protection-key="" mode=dynamic-keys mschapv2-password=""
mschapv2-username="" name=test radius-eap-accounting=no
XxxxxaaYyyyyyy wpa2-pre-shared-key=""
/interface wireless
set [ find default-name=wlan1 ] adaptive-noise-immunity=none allow-sharedkey=
no ampdu-priorities=0 amsdu-limit=8192 amsdu-threshold=8192 antenna-gain=
0 area="" arp=enabled arp-timeout=auto band=2ghz-b/g/n basic-rates-a/g=
6Mbps basic-rates-b=1Mbps bridge-mode=enabled channel-width=20/40mhz-Ce
compression=no country=norway default-ap-tx-limit=0
default-authentication=yes default-client-tx-limit=0 default-forwarding=
yes disable-running-check=no disabled=no disconnect-timeout=3s distance=
indoors frame-lifetime=0 frequency=2412 frequency-mode=regulatory-domain
frequency-offset=0 guard-interval=any hide-ssid=no ht-basic-mcs=
mcs-0,mcs-1,mcs-2,mcs-3,mcs-4,mcs-5,mcs-6,mcs-7 ht-supported-mcs="mcs-0,mc
s-1,mcs-2,mcs-3,mcs-4,mcs-5,mcs-6,mcs-7,mcs-8,mcs-9,mcs-10,mcs-11,mcs-12,m
cs-13,mcs-14,mcs-15,mcs-16,mcs-17,mcs-18,mcs-19,mcs-20,mcs-21,mcs-22,mcs-2
3" hw-fragmentation-threshold=disabled hw-protection-mode=none
hw-protection-threshold=0 hw-retries=7 interworking-profile=disabled
keepalive-frames=enabled l2mtu=1600 mac-address=4C:5E:0C:53:5D:BF
max-station-count=2007 mode=ap-bridge mtu=1500 multicast-buffering=
enabled multicast-helper=default name=wlan1 noise-floor-threshold=default
nv2-cell-radius=30 nv2-downlink-ratio=50 nv2-mode=dynamic-downlink
nv2-noise-floor-offset=default nv2-preshared-key="" nv2-qos=default
nv2-queue-count=2 nv2-security=disabled nv2-sync-secret=""
on-fail-retry-time=100ms preamble-mode=both radio-name=AAA-nett
rate-selection=advanced rate-set=default rx-chains=0,1 scan-list=default
secondary-channel="" security-profile=test ssid=A33
station-bridge-clone-mac=00:00:00:00:00:00 station-roaming=enabled
supported-rates-a/g=6Mbps,9Mbps,12Mbps,18Mbps,24Mbps,36Mbps,48Mbps,54Mbps
supported-rates-b=1Mbps,2Mbps,5.5Mbps,11Mbps tdma-period-size=2
tx-chains=0,1 tx-power-mode=default update-stats-interval=disabled
vlan-id=1 vlan-mode=no-tag wds-cost-range=50-150 wds-default-bridge=none
wds-default-cost=100 wds-ignore-ssid=no wds-mode=disabled
wireless-protocol=802.11 wmm-support=disabled wps-mode=disabled
/interface wireless manual-tx-power-table
set wlan1 manual-tx-powers="1Mbps:17,2Mbps:17,5.5Mbps:17,11Mbps:17,6Mbps:17,9M
bps:17,12Mbps:17,18Mbps:17,24Mbps:17,36Mbps:17,48Mbps:17,54Mbps:17,HT20-0:
17,HT20-1:17,HT20-2:17,HT20-3:17,HT20-4:17,HT20-5:17,HT20-6:17,HT20-7:17,H
T40-0:17,HT40-1:17,HT40-2:17,HT40-3:17,HT40-4:17,HT40-5:17,HT40-6:17,HT40-
7:17"
/interface wireless nstreme
set wlan1 disable-csma=no enable-nstreme=no enable-polling=yes framer-limit=
3200 framer-policy=none
/interface wireless align
set active-mode=yes audio-max=-20 audio-min=-100 audio-monitor=
00:00:00:00:00:00 filter-mac=00:00:00:00:00:00 frame-size=300
frames-per-second=25 receive-all=no ssid-all=no
/interface wireless cap
set bridge=none caps-man-addresses="" caps-man-certificate-common-names=""
caps-man-names="" certificate=none discovery-interfaces="" enabled=no
interfaces="" lock-to-caps-man=no static-virtual=no
/interface wireless sniffer
set channel-time=200ms file-limit=10 file-name="" memory-limit=10
multiple-channels=no only-headers=no receive-errors=no streaming-enabled=
no streaming-max-rate=0 streaming-server=0.0.0.0
/interface wireless snooper
set channel-time=200ms multiple-channels=yes receive-errors=no
