I have a strange issue where Apple devices are sometimes not reconnecting to the Mikrotik Chateau LTE 12 wireless networks after previously being connected. Not sure where to start, I have read of issues plaguing routerOS for years regarding Apple devices and wireless but cant find solutions. I have never previously had an issue with Apple devices connecting to any wireless network I have managed.
[admin@router01] /system> /system/routerboard/print
routerboard: yes
model: RBD53G-5HacD2HnD
serial-number: C8CA0CB0B626
firmware-type: ipq4000L
factory-firmware: 7.0beta6
current-firmware: 7.1beta2
upgrade-firmware: 7.1beta2
Wireless config:
[admin@router01] /interface/wireless> print
Flags: X - disabled; R - running
0 R name="wlan1" mtu=1500 l2mtu=1600 mac-address=48:8F:5A:11:24:DD arp=enabled interface-type=IPQ4019 mode=ap-bridge ssid="LIBERTY" frequency=auto band=2ghz-b/g/n channel-width=20/40mhz-Ce
secondary-channel="" scan-list=default wireless-protocol=802.11 vlan-mode=no-tag vlan-id=1 wds-mode=disabled wds-default-bridge=none wds-ignore-ssid=no bridge-mode=enabled
default-authentication=yes default-forwarding=yes default-ap-tx-limit=0 default-client-tx-limit=0 hide-ssid=no security-profile=default compression=no
1 name="wlan2" mtu=1500 l2mtu=1600 mac-address=48:8F:5A:11:24:DE arp=enabled interface-type=IPQ4019 mode=ap-bridge ssid="LIBERTY_AC" frequency=auto band=5ghz-onlyac channel-width=20/40mhz-Ce
admin@router01] /interface/wireless> security-profiles/print
Flags: * - default
0 * name="default" mode=dynamic-keys authentication-types=wpa2-psk unicast-ciphers=aes-ccm group-ciphers=aes-ccm wpa-pre-shared-key="xxxxxxxxxxxx" wpa2-pre-shared-key="xxxxxxxxxxxx"
supplicant-identity="MikroTik" eap-methods="" tls-mode=no-certificates tls-certificate=none mschapv2-username="" mschapv2-password="" disable-pmkid=no static-algo-0=none static-key-0=""
static-algo-1=none static-key-1="" static-algo-2=none static-key-2="" static-algo-3=none static-key-3="" static-transmit-key=key-0 static-sta-private-algo=none static-sta-private-key=""
radius-mac-authentication=no radius-mac-accounting=no radius-eap-accounting=no interim-update=0s radius-mac-format=XX:XX:XX:XX:XX:XX radius-mac-mode=as-username radius-called-format=mac:ssid
radius-mac-caching=disabled group-key-update=1h management-protection=disabled management-protection-key=""
