Apple Devices not roaming correctly?
Hi Mikrotik Community,
I have switched to new CAPsMAN a couple of weeks ago. My IoT Devices are (mostly) happy, and overall reception is way better than before.
Im running an RB5009 and 2 CAp ACs (running qcom-ac driver), all on 7.14.3, with 2 SSIDs. one purely on 2.4Ghz for IOT, and another one purely for 5Ghz.
My Iphone 14 Pro, the iPhone 13 from my Wife, my Macbook Pro all expiriencing “weird” Roaming behavior:
(70:31:xx:xx is my iPhone), behavior is identical for other devices.
 13:18:33 wireless,debug 70:31:7F:DE:D9:E2@Wifi-AP2 reauthenticating
 13:18:37 wireless,debug 70:31:7F:DE:D9:E2@Wifi-AP2 reauthenticating
 13:18:40 wireless,debug 70:31:7F:DE:D9:E2@Wifi-AP2 reauthenticating
 13:18:52 wireless,debug 70:31:7F:DE:D9:E2@Wifi-AP2 reauthenticating
 - here i switched wifi off on the device -
 13:59:47 wireless,info 70:31:7F:DE:D9:E2@Wifi-AP1 disconnected, connection lost, signal strength -66
 13:59:47 wireless,debug 70:31:7F:DE:D9:E2@Wifi-AP1 disassociated, connection lost, signal strength -66
 13:59:55 wireless,debug 70:31:7F:DE:D9:E2@Wifi-AP1 associated, signal strength -62
 13:59:55 wireless,info 70:31:7F:DE:D9:E2@Wifi-AP1 connected, signal strength -62
I have to turn of wifi, to have the device use the next AP.
Config:
[h1ghrise@Baranowice] /interface/wifi/configuration> pr
Flags: X - disabled
 0   name="CONFIG_WIFI" ssid="Wifi" country=Austria
     security.authentication-types=wpa2-psk,wpa3-psk .passphrase="[REDACTED]" .ft=yes .ft-over-ds=yes .connect-priority=0/1
     datapath=DP_AC
     datapath.bridge=BR-MAIN
     channel.band=5ghz-ac .width=20/40/80mhz .skip-dfs-channels=all
 1   name="CONFIG_IOT" ssid="IoT" country=Austria
     security.authentication-types=wpa-psk,wpa2-psk .passphrase="[REDACTED]" .wps=disable .ft=yes .ft-over-ds=yes
     datapath=DP_AC
     channel.frequency=2412,2437,2462 .band=2ghz-g .width=20mhz .skip-dfs-channels=all
I reduced txpower of my APs in capsman2 and now they are roaming much better!
I was doing this in capsman v1 as well, but heard that this is not necessary anymore. Can’t find the thread, but bottom line was, not to mess with radio power distribution/settings.
Can you kindly share how and where you reduced txpower? Its highly dynamic as it depends on location of aps, walls, etc.
The issue might be that device sees signal strength from both APs quite strong and almost the same (-66dB vs. -62dB is not much of a difference). Even with mobility enhancements (802.11 r/k/v) it’s still up to station to decide when to roam, the enhancements just give station additional information which helps it to decide and makes the reconnection process faster.
If it bothers you that device is not connected to the strongest AP and it’s the are where your device stays a lot of time, then you have to make larger difference in signal strengths of both APs. E.g. reduce power of AP which already provides the slightly lower signal strength (probably by some 10 dB). Or move one of APs so that signal strength at this particular spot drops considerably.
I ran into problems when using combined WPA2-PSK and WPA3-PSK, only on Apple devices.
In addition, I set DTIM to 3 (which is advised by Apple) and set group encryption explicitly to CCMP.
And, at last, I lowered 2.4GHz Tx power as well.
How to lower txpower efficiently? when using txpower in wireless configuration, it is mentioned it is unset per default. Value is an int between 0 and 40. So 30 would be a reduction by 10 dbm?
It is the actual Tx Power used by the radio (antenna gain is not part of the setting).
Mine is set to 5 dBm, which is sufficient for my environment. Think the neighbors appreciate it as well!
In Capsman V1, I did it exactly like that. Put the txpower with a fixed value (10 in my case).
Now there are different approaches.
txpower = radio transmit power - gain
So, if I raise the gain, I reduce the TX power ?
As both values are unset, raising the gain would efficiently lower the txpower by this amount?
Edit: I set the antenna gain to 10, and walked around the flat to see if it made any difference. As soon as i left the range from AP1, where the phone was connected to, and approached the second AP, i noticed that the signal level indicator in the phone was “flapping” (hard to describe, signal quality jumped between 1 bar and 4 bars). In the Router logs:
 16:39:17 wireless,debug 70:31:7F:DE:D9:E2@Wifi-AP2 reauthenticating
 16:39:18 wireless,debug 70:31:7F:DE:D9:E2@Wifi-AP2 reauthenticating
I moved back, log went silent.
Edit2: Removed gain and changed the txpower value directly to 7. Now Roaming seems to work fine:
Macbook (moving to AP2)
 16:46:48 wireless,debug F8:4D:89:92:04:06@Wifi-AP2 associated, signal strength -77
 16:46:48 wireless,info F8:4D:89:92:04:06@Wifi-AP1 roamed to F8:4D:89:92:04:06@Wifi-AP2, signal strength -77
 16:46:48 wireless,debug F8:4D:89:92:04:06@Wifi-AP1 disassociated, connected to other interface, signal strength -83
Macbook (moving to AP1)
 16:47:42 wireless,debug F8:4D:89:92:04:06@Wifi-AP1 associated, signal strength -65
 16:47:42 wireless,info F8:4D:89:92:04:06@Wifi-AP2 roamed to F8:4D:89:92:04:06@Wifi-AP1, signal strength -65
 16:47:42 wireless,debug F8:4D:89:92:04:06@Wifi-AP2 disassociated, connected to other interface, signal strength -82
Ok maybe i was a bit too enthusiastic.
I setup the 5Ghz main Wifi on all (Apple) Devices, which connect to it, again. forgot the network, setup password again and it seem to work, but now i saw this:
 13:56:10 wireless,info 04:99:BB:57:C5:3F@Wifi-AP1 disconnected, connection lost, signal strength -87
 13:56:15 wireless,info 04:99:BB:57:C5:3F@Wifi-AP2 connected, signal strength -62
Devices start to experience issues again, despite the clear distinction in signal levels and setup FT/roaming opportunity.
Is there anything else I may check?
I would expect some debug logging? Did you disable that?
Can you share the complete config?
/export file=anynameyoulike
Remove serial and any other private info.
yes - I had wireless debug disabled after roaming was working fine.
My config looks like this:
# 2024-05-11 20:33:04 by RouterOS 7.14.3
# software id = [REDACTED]
# model = RB5009UPr+S+
# serial number = [REDACTED]
/container mounts
add dst=/opt/adguardhome/conf name=adguard_conf src=\
    /usb1-part1/docker/conf/adguard
add dst=/config name=homeassistant src=\
    /usb1-part1/container/mounts/homeassistant/config
add dst=/mosquitto/config name=mqtt src=/usb1-part1/docker/mqtt/config
/disk
add parent=usb1 partition-number=1 partition-offset=512 partition-size=\
    "500 107 861 504" type=partition
add admin-mac=[REDACTED] auto-mac=no name=BR-MAIN port-cost-mode=short \
    protocol-mode=none vlan-filtering=yes
set [ find default-name=ether1 ] name="ether1 - WAN" poe-out=off
set [ find default-name=ether2 ] disabled=yes name="ether2 - Lab" poe-out=off
set [ find default-name=ether3 ] disabled=yes poe-out=off
set [ find default-name=ether4 ] disabled=yes poe-out=off
set [ find default-name=ether5 ] disabled=yes poe-out=off
set [ find default-name=ether6 ] name="ether6 - Zigbee"
set [ find default-name=ether7 ] name="ether7 - AP1"
set [ find default-name=ether8 ] name="ether8 - AP2"
set [ find default-name=sfp-sfpplus1 ] disabled=yes
/interface wireguard
add listen-port=31337 mtu=1420 name=VPN
/interface veth
add address=10.10.50.2/24 gateway=10.10.50.1 gateway6="" name=\
    "veth1 - AdGuard"
add address=10.10.20.2/24 gateway=10.10.20.1 gateway6="" name=\
    "veth2 - Homeassistant"
add address=10.10.20.6/24 gateway=10.10.20.1 gateway6="" name="veth3 - MQTT"
/interface vlan
add interface=BR-MAIN name="VLAN10 - Wifi" vlan-id=10
add interface=BR-MAIN name="VLAN20 - IoT" vlan-id=20
add interface=BR-MAIN name="VLAN50 - LAN" vlan-id=50
add comment=defconf name=WAN
add comment=defconf name=LAN
/interface wifi datapath
add bridge=BR-MAIN disabled=no name=DP_AC
/interface wifi configuration
add channel.band=5ghz-ac .skip-dfs-channels=all .width=20/40/80mhz country=\
    Austria datapath=DP_AC datapath.bridge=BR-MAIN disabled=no name=\
    CONFIG_WIFI security.authentication-types=wpa2-psk,wpa3-psk .ft=yes \
    .ft-over-ds=yes ssid=Wifi tx-power=5
add channel.band=2ghz-g .frequency=2412,2437,2462 .skip-dfs-channels=all \
    .width=20mhz country=Austria datapath=DP_AC datapath.bridge=BR-MAIN \
    disabled=no name=CONFIG_IOT security.authentication-types=\
    wpa-psk,wpa2-psk .ft=yes .ft-over-ds=yes .wps=disable ssid=IoT tx-power=5
add name=POOL_LAN ranges=10.10.50.2-10.10.50.254
add name=POOL_IOT ranges=10.10.20.2-10.10.20.254
add name=POOL_WIFI ranges=10.10.10.2-10.10.10.254
add address-pool=POOL_IOT interface="VLAN20 - IoT" lease-time=4w2d name=\
    DHCP-IOT
add address-pool=POOL_WIFI interface="VLAN10 - Wifi" lease-time=1w3d name=\
    DHCP-WIFI
add address-pool=POOL_LAN interface="VLAN50 - LAN" lease-time=14w2d name=\
    DHCP-LAN
/container
add hostname=SRV-AdGuard interface="veth1 - AdGuard" root-dir=\
    usb1-part1/docker/adguard start-on-boot=yes workdir=/opt/adguardhome/work
add interface="veth3 - MQTT" mounts=mqtt root-dir=usb1-part1/docker/mqtt/ \
    start-on-boot=yes
add comment=HomeAssistant envlist=ha_env interface="veth2 - Homeassistant" \
    mounts=homeassistant root-dir=usb1-part1/docker/ha start-on-boot=yes \
    workdir=/config
/container config
set registry-url=https://registry-1.docker.io tmpdir=usb1-part1/docker
/container envs
add key=TZ name=ha_env value=Europe/Vienna
add bridge=BR-MAIN comment="AP1" frame-types=\
    admit-only-vlan-tagged interface="ether7 - AP1" internal-path-cost=10 \
    path-cost=10
add bridge=BR-MAIN comment="AP2" frame-types=\
    admit-only-vlan-tagged interface="ether8 - AP2" internal-path-cost=10 \
    path-cost=10
add bridge=BR-MAIN frame-types=admit-only-untagged-and-priority-tagged \
    interface="veth1 - AdGuard" internal-path-cost=10 path-cost=10 pvid=50
add bridge=BR-MAIN interface="ether6 - Zigbee" internal-path-cost=10 \
    path-cost=10 pvid=20
    interface="veth3 - MQTT" internal-path-cost=10 path-cost=10 pvid=20
    interface="veth2 - Homeassistant" pvid=20
add bridge=BR-MAIN frame-types=admit-only-vlan-tagged interface=\
    "ether2 - Lab"
set udp-timeout=10s
/ipv6 settings
set accept-redirects=no accept-router-advertisements=no disable-ipv6=yes \
    forward=no
/interface bridge vlan
add bridge=BR-MAIN comment=Wifi tagged="BR-MAIN,ether7 - AP1,ether8 - AP2" \
    vlan-ids=10
add bridge=BR-MAIN comment=IoT tagged="BR-MAIN,ether7 - AP1,ether8 - AP2" \
    untagged="veth2 - Homeassistant" vlan-ids=20
add bridge=BR-MAIN comment=LAN tagged=\
    "BR-MAIN,ether7 - AP1,ether8 - AP2,ether2 - Lab" vlan-ids=50
add interface="ether1 - WAN" list=WAN
add interface=VPN list=LAN
add interface="VLAN10 - Wifi" list=LAN
add interface="VLAN20 - IoT" list=LAN
add interface="VLAN50 - LAN" list=LAN
/interface wifi capsman
set ca-certificate=[REDACTED] certificate=[REDACTED] \
    enabled=yes interfaces="VLAN50 - LAN" package-path="" \
    require-peer-certificate=no upgrade-policy=none
/interface wifi provisioning
add action=create-dynamic-enabled disabled=no master-configuration=\
    CONFIG_WIFI name-format=Wifi-%I supported-bands=5ghz-ac
add action=create-dynamic-enabled disabled=no master-configuration=CONFIG_IOT \
    name-format=IoT-%I supported-bands=2ghz-g
/interface wireguard peers
add allowed-address=10.10.99.2/32 comment="iPhone Ben" interface=VPN \
    public-key="[REDACTED]"
add allowed-address=10.10.99.3/32 comment="Macbook Ben" interface=VPN \
add address=10.10.99.1/24 comment=Wireguard interface=VPN network=10.10.99.0
add address=10.10.50.1/24 interface="VLAN50 - LAN" network=10.10.50.0
add address=10.10.10.1/24 interface="VLAN10 - Wifi" network=10.10.10.0
add address=10.10.20.1/24 interface="VLAN20 - IoT" network=10.10.20.0
/ip cloud
set ddns-enabled=yes
/ip dhcp-client
add comment=defconf interface="ether1 - WAN"
add address=10.10.10.0/24 gateway=10.10.10.1
add address=10.10.20.0/24 gateway=10.10.20.1
add address=10.10.50.0/24 dns-server=10.10.50.1 gateway=10.10.50.1
add address=10.13.37.0/24 gateway=10.13.37.1
set allow-remote-requests=yes
/ip dns static
/ip firewall address-list
add address=10.10.10.0/24 list=Management
add address=10.10.20.0/24 list=Management
add address=10.10.99.0/24 list=Management
    established,related,untracked
    invalid
add action=accept chain=input comment="Allow Router Management" dst-port=\
    8291,22,445,139 log-prefix=ACCESS: protocol=tcp src-address-list=\
    Management
add action=accept chain=input comment="Allow Wireguard" dst-port=31337 \
    protocol=udp
    in-interface-list=!LAN
    ipsec-policy=in,ipsec
    ipsec-policy=out,ipsec
    connection-state=invalid
/ip service
set telnet disabled=yes
set ftp disabled=yes
set www address=10.10.10.0/24,10.10.20.0/24,10.10.50.0/24,10.10.99.0/24
set ssh address=10.10.10.0/24,10.10.20.0/24,10.10.99.0/24
set api address=10.10.20.2/32
set winbox address=10.10.10.0/24,10.10.50.0/24,10.10.99.0/24
set api-ssl address=10.10.20.2/32 disabled=yes
/ip ssh
set strong-crypto=yes
/system clock
set time-zone-name=Europe/Vienna
/system logging
set 0 topics=info,!wireguard
add topics=debug,wireless
/system note
set show-at-login=no
/system script
add dont-require-permissions=yes name="Update HomeAssistant" owner=h1ghrise \
    policy=ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon \
    source=":local contComment \"HomeAssistant\"\r\
    \n:local logPrefix \"Container update: \"\r\
    \n\r\
    \n\r\
    \n:local abortWithMessage do={\r\
    \n  :log error \"\$(\$logPrefix)Error - \$1\"\r\
    \n  :error \$1\r\
    \n}\r\
    \n\r\
    \n/container\r\
    \n\r\
    \n:local contId [find where comment=\$contComment]\r\
    \n:if (\$contId = \"\") do={ \$abortWithMessage (\"container \$contComment\
    \_not found, aborting\") logPrefix=\$logPrefix }\r\
    \n\r\
    \n:local contStatus ([get \$contId]->\"status\")\r\
    \n:if (\$contStatus = \"extracting\") do={ \$abortWithMessage (\"container\
    \_\$contComment is extracting, aborting\") logPrefix=\$logPrefix }\r\
    \n\r\
    \n:log info \"\$(\$logPrefix)Container \$contComment update started\"\r\
    \n:local contStarted false\r\
    \n\r\
    \n:if (\$contStatus != \"stopped\") do={\r\
    \n  :if (\$contStatus = \"running\") do={\r\
    \n    :log warn \"\$(\$logPrefix)Container \$contComment is running, stopp\
    ing container\"\r\
    \n    :set contStarted true\r\
    \n    stop \$contId\r\
    \n  }\r\
    \n\r\
    \n  :local stopTimeoutSec 120\r\
    \n  :local sec 0\r\
    \n\r\
    \n  :while (([get \$contId]->\"status\") != \"stopped\" && \$sec <= \$stop\
    TimeoutSec) do={\r\
    \n    :delay 1\r\
    \n    :set sec (\$sec + 1)\r\
    \n  }\r\
    \n\r\
    \n  :if (\$sec > \$stopTimeoutSec) do={ \$abortWithMessage (\"container \$\
    contComment stop timed out, aborting\") logPrefix=\$logPrefix }\r\
    \n  :log info \"\$(\$logPrefix)Container \$contComment stopped\"\r\
    \n}\r\
    \n\r\
    \n:local cont [get \$contId]\r\
    \nremove \$contId\r\
    \n:delay 5\r\
    \n\r\
    \n\r\
    \n# after ROS upgrade check below if something has changed\r\
    \n# ------------------------------------------------------\r\
    \n# validAddArgs - array of container add command argument names which are\
    \_named exact as config property names\r\
    \n:local validAddArgs ( \"cmd\", \"comment\", \"dns\", \"domain-name\", \"\
    entrypoint\", \"envlist\", \"hostname\", \"interface\", \"logging\", \"mou\
    nts\", \"root-dir\", \"start-on-boot\", \"workdir\" )\r\
    \n# replaceArgs - key-value array for mapping container add command argume\
    nt name from different config property name, where key is config property \
    name and value is argument name\r\
    \n:local replaceArgs { \"tag\"=\"remote-image\" }\r\
    \n# addCmd - ROS CLI container add command\r\
    \n:local addCmd \"/container add\"\r\
    \n# -----------------------------------------------------\r\
    \n\r\
    \n\r\
    \n:local escapeStr do={\r\
    \n  :local strLen [:len \$1]\r\
    \n  :local escStr \"\"\r\
    \n\r\
    \n  :for i from=0 to=(\$strLen - 1) do={\r\
    \n    :local chr [:pick \$1 \$i (\$i + 1)]\r\
    \n\r\
    \n    :if (\$chr = \"\\\$\") do={ :set escStr \"\$escStr\\\\\\\$\" } else=\
    {\r\
    \n      :if (\$chr = \"\\\\\") do={ :set escStr \"\$escStr\\\\\\\\\" } els\
    e={\r\
    \n        :if (\$chr = \"\\\"\") do={ :set escStr \"\$escStr\\\\\\\"\" } e\
    lse={\r\
    \n          :set escStr \"\$escStr\$chr\"\r\
    \n        }\r\
    \n      }\r\
    \n    }\r\
    \n  }\r\
    \n\r\
    \n  :return \"\\\"\$escStr\\\"\"\r\
    \n}\r\
    \n\r\
    \n:local arrayToStr do={\r\
    \n  :local arrLen [:len \$1]\r\
    \n  :local strArr \"(\"\r\
    \n\r\
    \n  :for i from=0 to=(\$arrLen - 1) do={\r\
    \n    :local item [:pick \$1 \$i]\r\
    \n\r\
    \n    :if ([:len \$strArr] > 1) do={ :set \$strArr \"\$strArr,\" }\r\
    \n    :if ([:typeof \$item] = \"str\") do={\r\
    \n      :set \$strArr \"\$strArr\$([\$escapeStr \$item])\"\r\
    \n    } else={\r\
    \n      :set \$strArr \"\$strArr\$item\"\r\
    \n    }\r\
    \n  }\r\
    \n\r\
    \n  :return \"\$strArr)\"\r\
    \n}\r\
    \n\r\
    \n:local escapeValue do={\r\
    \n  :if ([:typeof \$1] = \"str\") do={ :return [\$escapeStr \$1] }\r\
    \n  :if ([:typeof \$1] = \"array\") do={ :return [\$arrayToStr \$1 escapeS\
    tr=\$escapeStr] }\r\
    \n  :if ([:typeof \$1] = \"bool\") do={:if (\$1) do={ :return \"yes\" } el\
    se={ :return \"no\" }}\r\
    \n  :return \$1\r\
    \n}\r\
    \n\r\
    \n:foreach k,v in=\$cont do={\r\
    \n  :if ([:len \$v] != 0) do={\r\
    \n    :if ([:find \$validAddArgs \$k] >= 0) do={\r\
    \n      :set addCmd \"\$addCmd \$k=\$([\$escapeValue \$v escapeStr=\$escap\
    eStr arrayToStr=\$arrayToStr])\"\r\
    \n    } else={\r\
    \n      :local rk (\$replaceArgs->\"\$k\")\r\
    \n      :if ([:typeof \$rk] != \"nothing\") do={ :set addCmd \"\$addCmd \$\
    rk=\$([\$escapeValue \$v escapeStr=\$escapeStr arrayToStr=\$arrayToStr])\"\
    \_}\r\
    \n    }\r\
    \n  }\r\
    \n}\r\
    \n\r\
    \n:execute \"\$addCmd\" as-string\r\
    \n:set contId [find where comment=\$contComment]\r\
    \n:if (\$contId = \"\") do={ \$abortWithMessage (\"unable to add container\
    \_\$contComment, check add command: \$addCmd\") logPrefix=\$logPrefix }\r\
    \n\r\
    \n# rise if not enough (30min) on slow network or device\r\
    \n:local extrTimeoutSec 1800\r\
    \n:local sec 0\r\
    \n\r\
    \n:while (([get \$contId]->\"status\") = \"extracting\" && \$sec <= \$extr\
    TimeoutSec) do={\r\
    \n  :delay 1\r\
    \n}\r\
    \n\r\
    \n:if (\$sec > \$extrTimeoutSec) do={ \$abortWithMessage (\"container \$co\
    ntComment extract wait timed out, something is failed or slower than expec\
    ted\") logPrefix=\$logPrefix }\r\
    \n:if (\$contStarted) do={ start \$contId }\r\
    \n:log info \"\$(\$logPrefix)Container \$contComment update finished\""
/tool bandwidth-server
set enabled=no
/tool graphing interface
/tool graphing resource
add allow-address=10.10.10.130/32 store-on-disk=no
/tool mac-server
/tool mac-server mac-winbox
/tool mac-server ping
set enabled=no
/tool romon
set enabled=yes
Apple recommends using the same SSID across all bands on your wifi network. Not doing so can cause compatibility issues(according to Apple).
Have you tried using the same SSID for both bands ?
Only the 5Ghz WIFI SSID is used for the Apple Devices. IoT on 2.4 Ghz is not known to them
Frequency is handled by CapsMan and not restricted. So, I should restrict the used frequency on both APs, and set it manually to the same one?
i want to ask again for help, since I am not able to figure out my mistake.
I moved to a new apartment, and changed my cap ACs to cap AX APs. the RB5009 was also replaced with another one, so basically all brand new hardware :wink:
Setup is basically identical.
  • RB5009 as CapsMan
  • 3 VLANs (IOT, WIFI, MGMT)
  • 2 CAP AX
All devices run 7.16.1
Apple devices initially connect to one of the APs, but do not roam. If they do, I get full reception on the device, but I cant do anything (no page loads, no app, etc.). It’s like I’m not connected to the Internet. Disconnecting from Wifi, and manually connecting, fixes the issue.
I notices as well, that connecting to the AP takes a LOT of time (up to 2-3 minutes).
Log from earlier today:
20:08:41 wireless,info 70:31:7F:DE:D9:E2@Wifi-AP1 disconnected, connection lost, signal strength -88
20:08:41 wireless,debug 70:31:7F:DE:D9:E2@Wifi-AP1 disassociated, connection lost, signal strength -88
iPhone should roam to AP2, but does not.
Reconnect to stronger AP2:
20:08:43 wireless,debug 70:31:7F:DE:D9:E2@Wifi-AP2 associated, signal strength -55
20:08:43 wireless,info 70:31:7F:DE:D9:E2@Wifi-AP2 connected, signal strength -55
Again disconnected and connection to wifi manually disabled (and reenabled) on iPhone.
20:09:38 wireless,info 70:31:7F:DE:D9:E2@Wifi-AP2 disconnected, connection lost, signal strength -81
20:09:38 wireless,debug 70:31:7F:DE:D9:E2@Wifi-AP2 disassociated, connection lost, signal strength -81
Notice the delay until connection to AP1 is made successfully. Nearly 3 Minutes passed until a successful connection to AP is made
20:12:08 wireless,debug 70:31:7F:DE:D9:E2@Wifi-AP1 associated, signal strength -68
20:12:08 wireless,info 70:31:7F:DE:D9:E2@Wifi-AP1 connected, signal strength -68
My configs:
RB5009:
add admin-mac=D4:01:C3:B8:8B:7D auto-mac=no name=BR-MAIN protocol-mode=none
set [ find default-name=ether2 ] name="ether2 - AP1"
set [ find default-name=ether3 ] name="ether3 - AP2"
/interface vlan
add interface=BR-MAIN name=VLAN10_WIFI vlan-id=10
add interface=BR-MAIN name=VLAN20_IOT vlan-id=20
add interface=BR-MAIN name=VLAN50_MGMT vlan-id=50
add bridge=BR-MAIN disabled=no name=DP_WIFI vlan-id=10
add bridge=BR-MAIN disabled=no name=DP_IOT vlan-id=20
/interface wifi security
add authentication-types=wpa2-psk disabled=no ft=yes ft-over-ds=yes name=\
    SEC_WIFI
add authentication-types=wpa2-psk disabled=no ft=no ft-over-ds=no name=\
    SEC_IOT wps=disable
add channel.band=5ghz-ax .skip-dfs-channels=all .width=20/40mhz country=\
    Austria datapath=DP_WIFI disabled=no name=CFG_WIFI security=SEC_WIFI \
    ssid=Owcahome
    .width=20mhz country=Austria datapath=DP_IOT disabled=no name=CFG_IOT \
    security=SEC_IOT ssid=IoT
add name=POOL_MGMT ranges=10.10.50.2-10.10.50.254
add address-pool=POOL_WIFI interface=VLAN10_WIFI lease-time=1d name=DHCP_WIFI
add address-pool=POOL_MGMT interface=VLAN50_MGMT lease-time=1h name=DHCP_MGMT
add address-pool=POOL_IOT interface=VLAN20_IOT name=DHCP_IOT
add bridge=BR-MAIN interface="ether2 - AP1"
add bridge=BR-MAIN interface="ether3 - AP2"
add bridge=BR-MAIN tagged="BR-MAIN,ether2 - AP1,ether3 - AP2" vlan-ids=50
add bridge=BR-MAIN tagged="BR-MAIN,ether2 - AP1,ether3 - AP2" vlan-ids=20
add bridge=BR-MAIN tagged="BR-MAIN,ether2 - AP1,ether3 - AP2" vlan-ids=10
add interface=VLAN10_WIFI list=LAN
add interface=VLAN20_IOT list=LAN
add interface=VLAN50_MGMT list=LAN
set ca-certificate=auto certificate=auto enabled=yes interfaces=VLAN50_MGMT \
    package-path="" require-peer-certificate=no upgrade-policy=none
add action=create-dynamic-enabled disabled=no master-configuration=CFG_WIFI \
    name-format=Wifi-%I slave-configurations="" supported-bands=5ghz-ax
add action=create-dynamic-enabled disabled=no master-configuration=CFG_IOT \
    name-format=IoT-%I slave-configurations="" supported-bands=2ghz-g
add address=10.10.10.1/24 interface=VLAN10_WIFI network=10.10.10.0
add address=10.10.20.1/24 interface=VLAN20_IOT network=10.10.20.0
add address=10.10.50.1/24 interface=VLAN50_MGMT network=10.10.50.0
/ip dhcp-client
add address=10.10.50.0/24 gateway=10.10.50.1
set allow-remote-requests=yes mdns-repeat-ifaces=VLAN10_WIFI,VLAN20_IOT
add address=10.10.10.0/24 list=Wifi
add address=10.10.20.20 list=SONOS
add address=10.10.20.21 list=SONOS
    invalid
add action=accept chain=forward comment="Sonos to Controller" \
    dst-address-list=SONOS dst-port=1400 protocol=tcp src-address-list=Wifi
/ip ipsec profile
/system clock
/system logging
add topics=wireless,debug
/tool mac-server
/tool romon
set enabled=yes
AP1 config:
add admin-mac=D4:01:C3:FA:36:68 auto-mac=no comment=defconf name=BR-MAIN \
    port-cost-mode=short protocol-mode=none
set [ find default-name=ether1 ] name="ether1 - Router"
set [ find default-name=ether2 ] poe-out=off
/interface vlan
add bridge=BR-MAIN disabled=no name=DP_MAIN
add bridge=BR-MAIN comment=defconf interface=ether2 internal-path-cost=10 \
    path-cost=10
add bridge=BR-MAIN comment=defconf interface=wifi1 internal-path-cost=10 \
    path-cost=10
add bridge=BR-MAIN comment=defconf interface=wifi2 internal-path-cost=10 \
    path-cost=10
add bridge=BR-MAIN interface="ether1 - Router"
set udp-timeout=10s
add bridge=BR-MAIN tagged="BR-MAIN,ether1 - Router" vlan-ids=50
add comment=defconf interface=BR-MAIN list=LAN
/interface wifi cap
set discovery-interfaces=VLAN50_MGMT enabled=yes slaves-datapath=DP_MAIN
/ip dhcp-client
/ip dns static
add address=192.168.88.1 comment=defconf name=router.lan type=A
    invalid
/ip ipsec profile
/ipv6 firewall address-list
/ipv6 firewall filter
    invalid
    icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" port=\
    33434-33534 protocol=udp
    udp src-address=fe80::/10
    protocol=udp
    ipsec-ah
    ipsec-esp
    !LAN
    icmpv6
    500,4500 protocol=udp
    ipsec-ah
    ipsec-esp
    !LAN
/system clock
/system identity
set name=AP1
/system note
/system routerboard mode-button
set enabled=yes on-event=dark-mode
/system script
add comment=defconf dont-require-permissions=no name=dark-mode owner=*sys \
    source="\r\
    \n   :if ([system leds settings get all-leds-off] = \"never\") do={\r\
    \n     /system leds settings set all-leds-off=immediate \r\
    \n   } else={\r\
    \n     /system leds settings set all-leds-off=never \r\
    \n   }\r\
    \n "
/tool mac-server
/tool romon
set enabled=yes
AP2 (mostly identical):
add admin-mac=D4:01:C3:F8:B8:33 auto-mac=no comment=defconf name=BR-MAIN \
/interface vlan
    path-cost=10
    path-cost=10
    path-cost=10
add bridge=BR-MAIN interface="ether1 - Router" internal-path-cost=10 \
    path-cost=10
set udp-timeout=10s
add bridge=BR-MAIN tagged="ether1 - Router,BR-MAIN" vlan-ids=50
/interface wifi cap
/ip dhcp-client
add comment=defconf interface=VLAN50_MGMT
/ip dns static
    invalid
/ip ipsec profile
    invalid
    icmpv6
    protocol=udp
    ipsec-ah
    ipsec-esp
    !LAN
    icmpv6
    ipsec-ah
    ipsec-esp
    !LAN
/system clock
/system identity
set name=AP2
/system note
/system script
    source="\r\
    \n   } else={\r\
    \n   }\r\
    \n "
/tool mac-server
/tool romon
set enabled=yes
I can’t figure it out.
Why do your AP have a firewall?
I prefer to follow the documentation on the CAP, in combination with bridge VLAN filtering for the ethernet ports.
By leaving the 5GHz channel to auto, it is possible that the AP’s are using the same frequencies. That could be a reason for having bad roaming experience. Check the frequencies or (better) set the (non overlapping) frequencies manually.
Why did you cut out wifi interfaces from the config?
thanks for your hints. I was reading a bit more and adapted my configuration.
  • enabled vlan-filtering on bridge on Capsman (RB5009). I somehow overlooked this setting. I noticed that the caps are listed as untagged for pvid 1 - is this normal? (VLAN filtering is not enabled on CAP`s bridge) For the other VLANs (10,20,50) bridge lists them as tagged.
add bridge=BR-MAIN comment=Management tagged=\
add bridge=BR-MAIN comment=IoT tagged="BR-MAIN,ether2 - AP1,ether3 - AP2" \
    untagged="ether4 - Printer" vlan-ids=20
add bridge=BR-MAIN comment=WiFi tagged="BR-MAIN,ether2 - AP1,ether3 - AP2" \
    vlan-ids=10
  • split up the wifi configuration, and added individual frequencies for all radios (as suggested by erlinden in a different post). I want to avoid DFS channels, so I chose CH149 (short range). Are there any downsides?
/interface wifi channel
add disabled=no frequency=2412 name="CH 1 (2412)" width=20mhz
add disabled=no frequency=2437 name="CH 6 (2437)" width=20mhz
add disabled=no frequency=2462 name="CH 11(2462)" width=20mhz
add disabled=no frequency=5180 name="CH 36 (5180)" width=20/40/80mhz
add disabled=no frequency=5260 name="CH 52 (5260)" width=20/40/80mhz
add disabled=no frequency=5500 name="CH 100 (5500)" width=20/40/80mhz
add disabled=no frequency=5680 name="CH 136 (5680)" width=20/40/80mhz
add disabled=no frequency=5745 name="CH 149 (5745) SRD" width=20/40/80mhz
    SEC_WIFI wps=disable
    SEC_IOT wps=disable
add channel="CH 149 (5745) SRD" channel.skip-dfs-channels=all country=Austria \
    datapath=DP_WIFI disabled=no name=WIFI-AP2-CH149 security=SEC_WIFI ssid=\
    Owcahome
add channel="CH 36 (5180)" channel.skip-dfs-channels=all country=Austria \
    datapath=DP_WIFI disabled=no name=WIFI-AP1-CH36 security=SEC_WIFI ssid=\
    Owcahome
add channel="CH 1 (2412)" channel.skip-dfs-channels=all country=Austria \
    datapath=DP_IOT disabled=no name=IOT-AP1-CH1 security=SEC_IOT ssid=IoT
add channel="CH 6 (2437)" channel.skip-dfs-channels=all country=Austria \
    datapath=DP_IOT disabled=no name=IOT-AP2-CH6 security=SEC_IOT ssid=IoT
add action=create-dynamic-enabled comment="5GHZ WIFI - AP1 CH36" disabled=no \
    master-configuration=WIFI-AP1-CH36 name-format=Wifi-%I radio-mac=\
    [REDACTED]  slave-configurations="" supported-bands=5ghz-ax
add action=create-dynamic-enabled comment="2.4 GHZ IOT - AP1 CH1" disabled=no \
    master-configuration=IOT-AP1-CH1 name-format=IoT-%I radio-mac=\
    [REDACTED] slave-configurations="" supported-bands=2ghz-g
add action=create-dynamic-enabled comment="5GHZ WIFI - AP2 CH100" disabled=no \
    master-configuration=WIFI-AP2-CH149 name-format=Wifi-%I radio-mac=\
    [REDACTED]  supported-bands=5ghz-ax
add action=create-dynamic-enabled comment="2.4GHZ - AP2 CH6" disabled=no \
    master-configuration=IOT-AP2-CH6 name-format=IoT-%I radio-mac=\
    [REDACTED] supported-bands=2ghz-g
Unfortunately no change visible. Devices are not roaming at all. With the previous setup (cap AC) and the vlan setup handled on the cap, it was working well.
Exported also the interfaces from all devices (attached)
AP1_interface.rsc (1.76 KB)
RB5009_interface.rsc (4.39 KB)
AP2_interface.rsc (1.68 KB)
I found the misconfiguration.
Bridge on the caps had
protocol-mode=none
set.
After enabling RTSP, all issues went away.
