Apple Products detected as port scanners
Hi Everyone.
I have a hotspot setup for a client and the apple users (macbook, iPhone, iPad etc) keep getting picked up as port scanners in the mikrotik firewall. Can you suggest anything that may be causing this? Windows, Blackberry’s, Android users have no issues. Only Macs.
My firewall rules are as follows:
add chain=forward protocol=tcp dst-port=25 src-address-list=spammer action=drop comment=“BLOCK SPAMMERS OR INFECTED USERS”
add chain=forward protocol=tcp dst-port=25 connection-limit=30,32 limit=50,5 action=add-src-to-address-list address-list=spammer address-list-timeout=1d comment=“Detect and add-list SMTP virus or spammers”
add chain=input protocol=tcp dst-port=21 src-address-list=ftp_blacklist action=drop
add chain=output action=accept protocol=tcp content=“530 Login incorrect” dst-limit=1/1m,9,dst-address/1m
add chain=output action=add-dst-to-address-list protocol=tcp content=“530 Login incorrect”
address-list=ftp_blacklist address-list-timeout=3h
add chain=input protocol=tcp dst-port=22 src-address-list=ssh_blacklist action=drop
comment=“drop ssh brute forcers” disabled=no
add chain=input protocol=tcp dst-port=22 connection-state=new
src-address-list=ssh_stage3 action=add-src-to-address-list address-list=ssh_blacklist
address-list-timeout=10d comment=“” disabled=no
src-address-list=ssh_stage2 action=add-src-to-address-list address-list=ssh_stage3
address-list-timeout=1m comment=“” disabled=no
add chain=input protocol=tcp dst-port=22 connection-state=new src-address-list=ssh_stage1
action=add-src-to-address-list address-list=ssh_stage2 address-list-timeout=1m comment=“” disabled=no
add chain=input protocol=tcp dst-port=22 connection-state=new action=add-src-to-address-list
address-list=ssh_stage1 address-list-timeout=1m comment=“” disabled=no
add chain=input protocol=tcp psd=21,3s,3,1 action=add-src-to-address-list address-list=“port scanners” address-list-timeout=2w comment="Port scanners to list " disabled=no
add chain=input protocol=tcp tcp-flags=fin,!syn,!rst,!psh,!ack,!urg action=add-src-to-address-list address-list=“port scanners” address-list-timeout=2w comment=“NMAP FIN Stealth scan”
add chain=input protocol=tcp tcp-flags=fin,syn action=add-src-to-address-list address-list=“port scanners” address-list-timeout=2w comment=“SYN/FIN scan”
add chain=input protocol=tcp tcp-flags=syn,rst action=add-src-to-address-list address-list=“port scanners” address-list-timeout=2w comment=“SYN/RST scan”
add chain=input protocol=tcp tcp-flags=fin,psh,urg,!syn,!rst,!ack action=add-src-to-address-list address-list=“port scanners” address-list-timeout=2w comment=“FIN/PSH/URG scan”
add chain=input protocol=tcp tcp-flags=fin,syn,rst,psh,ack,urg action=add-src-to-address-list address-list=“port scanners” address-list-timeout=2w comment=“ALL/ALL scan”
add chain=input protocol=tcp tcp-flags=!fin,!syn,!rst,!psh,!ack,!urg action=add-src-to-address-list address-list=“port scanners” address-list-timeout=2w comment=“NMAP NULL scan”
add chain=input src-address-list=“port scanners” action=drop comment=“dropping port scanners” disabled=no
END
Any suggestions?
Thanks,
BrnM.
anybody???
What is comment in address list? Let’s start by determining which rule has added Apple devices to port-scanners list.
Apple devices are very chatty in general, relax the rule a bit or add another rule specific to detected apple devices. It advertises and tries to discover other services on the network.
Bonjour generally uses
5297 TCP
5298 TCP/UDP
5353 UDP
You can set up a list when they get detected and apply a port scan detection rule with that in mind.
Davis / MCT: Thank you for your responses.
Here is an example of what it says in the address list.
2 D port scanners 192.168.25.135
4 D port scanners 192.168.25.124
MCT:
How would I relax these rules so users in my subnet 192.168.25.0/24 would not be triggering them as port scanners?
Thanks in advance,
BrnM.
add action=add-src-to-address-list address-list=bonjour address-list-timeout=15m chain=forward disabled=no dst-port=5353 protocol=udp
And move them above the port scan detection and modify the port scan detection with
src-address-list=!bonjour
It detected my mac off the UDP rule. I don’t know how often bonjour polls but 15 minutes is a safe buffer. I cut the rules down to the one my mac kept triggering.
**add action=add-src-to-address-list address-list=bonjour address-list-timeout=15m chain=forward disabled=no dst-port=5297,5298 protocol=tcp comment=“Apple Bonjour”
add action=add-src-to-address-list address-list=bonjour address-list-timeout=15m chain=forward disabled=no dst-port=5298,5353 protocol=udp**
add chain=input protocol=tcp psd=21,3s,3,1 src-address-list=!bonjour action=add-src-to-address-list address-list=“port scanners” address-list-timeout=2w comment="Port scanners to list " disabled=no
Like that?
Try that
Hi MCT.
I’ve made the adjustments that you suggested and it has worked for most of the apple users, however I am still picking up one or two every hour being listed as port scanners.
Any further suggestions? Are my firewall rules too strict? Ive used the script for 4 years and never had any issue like this before.
Thanks,
BrnM.
