I’m having wifi issues with Apple devices (ipads and iphones). I believe the Apple devices enters some micro-sleep causing Mikrotik to disconnect them. A typical log looks like the following:
10:48:01 wireless,info xx:xx:xx:xx:xx:xx@wlan1: connected
10:48:51 wireless,info xx:xx:xx:xx:xx:xx@wlan1: disconnected, extensive data loss
10:52:00 wireless,info wlan1: data from unknown device xx:xx:xx:xx:xx:xx, sent deauth
10:52:01 wireless,info xx:xx:xx:xx:xx:xx@wlan1: connected
This happens for all versions of Mikrotik 6.x that I have tried. The iOS devices are running 7.x and 8.x.
I have tried to adjust various settings, but none of them have improved the situation. The following tuning parameters have been adjusted:
Can I keep my existing wireless settings and just enable wireless-fp? Is it possible to revert the change by disabling the package (e.g. system package disable wireless-fp)?
It seems as this appen for newer Apple IOS devices. iPhone 4s does not give this problem, but iPhone 5s and iPad Mini v2 does. Perhaps a newer wifi chipset with new power save functionality gives problem with Mikrotik implementation?
we have not seen such issues with our “newer apple devices”, so please enable wireless-fp and debug logs, and see what is going on in there when you use the new package
