AppleStore not working with Mikrotik
I am running the firmware 6.37.1 on an access point based on the RouterBoard 91xG 5HPnd for home use; the mikrotik is bridging wireless devices to the local LAN (no nat , no firewall) and I am facing the following problem : apple devices can’t download apps from Apple store , they can login , browse the store but when they ask for download an app the pop up asking the Apple account password is showed up but after they type the password the connection is dropped. I tried using a “normal” access point and this beahvior doesn’t happen.
Anyone is facing the same problem ?
Thank you
Same here… Any solution or workaround so far?
CAPsMAN with HotSpot on 6.40.4.
