We are a scout campsite in the UK, with a few devices on “our network” like IP Phones, IP CCTV Cameras, a couple of computers, a couple of servers etc, and an authenticated Wireless network for campers and people who book our residential buildings. I am in the process of swapping our site firewall over to a MikroTik (we’ve ordered an RB4011 box).
We’re going to use the Hotspot feature for our authenticated wireless network. The authentication will be handled via RADIUS to our Active Directory server. I’ve got instructions for how to do this already, so am confident that I can get this bit working.
So, at this point, users will be able to login to our wireless network.
What I would like to be able to do is apply filter rules in the firewall that allow certain users (or groups of users) more access to things on other VLANs or Bridges.
For example:
Hotspot will be setup on ether4 (VLAN =40, IP range will be something like 192.168.40.0\22)
“Our Network” is on ether1 (VLAN=10, IP range will be 192.168.10.0\23).
I have an Address-List setup for the 4 or 5 Printers we have on site (eg, 192.168.10.20-192.168.10.29).
Our AD Server has a group setup called “Staff” for the volunteer campsite crew
I would like a firewall rule that blocks all access from VLAN40 to VLAN10 → this bit is easy
I would then like a series of rules that open up the access from VLAN40 to VLAN10 based on a user’s AD Group Membership (via the RADIUS authentication) eg, Staff can access the devices in my Printers address list from their laptops but guests (i.e. campers) wouldn’t be able to.
Any ideas? I can’t see an obvious place where I can specify which user groups or so a filter rule applies to.
The way to do this would be to prepare some rules in the firewall that match on a src-address-list (e.g. src-address-list=staff) and allow the extra traffic, then dynamically add the members of that group to that address-list when they connect.
How to do that, is a different matter. With PPP (and related protocols) it is easy as you can specify the name of an address-list where the current connection is to be added.
But with hotspot, I am not sure. Maybe others can add that info.
Hi @pe1chl,
Thanks for the reply. This is extremely useful.
When you say “add the members of that group to the address list when they connect”, presumably you mean add the IP-Address that they are assigned when they connect to the address list right? So that the connection is then allowed.
How would the list get refreshed though as the IP-Addresses will eventually get re-used when new clients connect.
I just had a quick look at the address lists that I’ve got setup and I couldn’t see any sort of expiry or anything like this.
Thanks…
Colin
Ignore my last post - just found the timeout option and have had a play and that does indeed purge the list of expired addresses.
So, I guess I just need to setup something via the RADIUS that does a check to see if the connection is still live and keeps extending the timeout or something.
You could also use a different VLAN for the members of the Staff group. It is possible to specify a VLAN in the RADIUS response and it works on plain WiFi, I do not know about hotspot.
This would mean you need to add another subnet (with DHCP config) for the staff members, and in the firewall you can use that for rules.
Unfortunately MikroTik use a nonstandard RADIUS attribute for specification of the VLAN. You will likely need to add it to the Windows RADIUS server.
I use freeradius and it already exists in one of the manufacturer-specific attribute defs, like this:
The only downside to the option above is that you need to manage the static IP’s and the firewall address lists. Not a problem with the printers, but depending on the amount of turn over you have on those with access to the printers in VLAN40, that could add up.
Just easier to have a new VLAN for staff that has access to the VLAN40 and VLAN10.
I’ve seen that it’s possible to set login/logout scripts for Hotspot logins, and that it’s possible to get things like username, Mac-ID, etc.
Is there anywhere that describes the built in parameters that are accessible this way? I can see that I have to declare local variables in order to make easy use of these, but it wasn’t clear to me from reading the MikroTik website so far, what parameters were actually available to me.
Do you think it would be possible to access the AD group memberships via RADIUS this way?
I’d prefer not to have to set fixed IPs for people - we’re all volunteers and the turnover can be a bit high sometimes.
Just to close this one off, and for anyone else who needs a similar solution… I got the effect I wanted by setting up different Hotspot User profiles and passing the parameter to select the user profile from Radius (based on the Network Policy Server settings, which does obey the AD Groups).
Each of the Hotspot user profiles was setup to populate a specific address list, and I applied the firewall rules to the address lists… and everything works exactly as I want it to
Thanks to everyone who posted help here - it really did help me to get along the way to the final solution.
