ap's dont see it
hi:
I have 2 diferents types of links one of 5.6 Km and works fine but the other of 6 Km don’t work, I do a scan but can’t see each other, the four have the wds mode active and the two have clean see eacho other.
and the other link is around the 8 Km and works fine, I don’t know what happend. plase help me
thanks
Have you check both AP on the ground, give them same small helical antenna and connect to the same AP. Same distance, and see the signal strength. Maybe you have problem in connector or cable.
yes, I checke the connectors, etc…
I make a test, a 1/2 km I have a link but not strong, I think this is a problem, but is the first time that happend to me, maybe this is the problem but is dificult to me going from place to place every day,
I have MT Os 2.9.22 in the 2 of then, I upgrated from 2.9.5, I don’t know why when I buy it have this OS.
The frequency is 5GHz, and a few moment climb the tower and I look, no problems of LOS only a 900Mgz antenna in the left of the LOS.
and I know this works because I saw other antennas around but not the interest one.
the 2 are ap-bridge, with wds, 33dbi antenna, 1.5 mt LR400.
I mean, make a test comparasion on the ground.
If one of the equipment have much smaller signal, I think it’s hardware or cable or connector problem. You have to fix or replace it.
