I am trying to use the MikroTik media converter (RBFTC11) to connect a server to my copper network using a couple of MikroTik fibre SFPs (S-85DLC05D). However, I can’t get a connection. When I plug in the SFP into the media converter, the SFP indicator light does not turn on.
Interestingly, I have also tried the same setup with two MikroTik copper SFPs (S-RJ01). In this case, the SFP light turns on and I can communicate with the server.
Can anyone confirm if the S-85DLC05D SFPs are compatible with the RBFTC11 media converter?
If so, is there something wrong with my setup? I have included a diagram of my setup below.
│ Server │ │ MikroTik RBFTC11 │
│ SFP│┼┼┼┼┼┼┼│ ├────────────────┤ │┼┼┼┼┼┼┼│SFP │
│ └───────┴──┘ LC/LC OM3 MM └──┴───────┘ │
│ S-85DLC05D S-85DLC05D │
┌─┤ │RJ45 │
CAT-5A│
│ │ Ethernet Switch │
└─┤ │RJ45 │
│ Laptop │ │ │
│ │ │ │RJ45 │
│ RJ45│ ├────────────────┤ │RJ45 │
│ └──┬──┘ CAT-5A └──┬──┘ │
