Hello all. Just switched from old Google Nest mesh network as support ran out. I’ve discovered Mikrotik and wasn’t discouraged by the steep learning curve. However as alot rides on a good FW setup I would much appreciate feedback to what I have made. I have not searched forum or watched 1000 YouTube videos as I wouldnt know if it be worth using in my SOHO network. We are just a family of 5 where the 3 are young teenagers hauling home friends for LAN partys etc. I think you get the picture. So I’ve made some VLANs but it’s mostly the firewall order I might have doubt about.
Thx in advance for all the help and especially suggestions for changes I should make or add.
Cheers from Denmark and sorry if I’ve pasted the wrong info
# feb/25/2023 08:00:54 by RouterOS 7.7
# software id = MWKQ-T6XU
# model = RB5009UG+S+
# serial number = xxxxxxxxx
add name=Bridge_VLAN20_IoT
add name=Bridge_VLAN30_Guest
add admin-mac=xxxxxxxxxxxxx auto-mac=no name=LAN_Bridge
set [ find default-name=ether2 ] mac-address=xxxxxxxxxxxxx
/interface wireguard
add listen-port=13231 mtu=1420 name="WireGuard MikroTik"
/interface vlan
add interface=ether5 name=VLAN20_Eth5_IoT vlan-id=20
add interface=ether5 name=VLAN30_Eth5_Guest vlan-id=30
add comment=defconf name=WAN
add comment=defconf name=LAN
add name="DHCP LAN" ranges=10.0.0.100-10.0.0.254
add name="DHCP VLAN20" ranges=10.0.20.150-10.0.20.254
add name="DHCP VLAN30" ranges=10.0.30.150-10.0.30.254
add address-pool="DHCP VLAN20" interface=Bridge_VLAN20_IoT lease-time=1d \
name="DHCP VLAN20"
add address-pool="DHCP VLAN30" interface=Bridge_VLAN30_Guest lease-time=1d \
name="DHCP VLAN30"
add address-pool="DHCP LAN" interface=LAN_Bridge lease-time=1d name=\
"DHCP Standard"
add bridge=Bridge_VLAN20_IoT comment=defconf interface=ether3
add bridge=LAN_Bridge comment=defconf interface=ether4
add bridge=LAN_Bridge comment=defconf interface=ether5
add bridge=LAN_Bridge comment=defconf interface=ether6
add bridge=Bridge_VLAN20_IoT comment=defconf interface=ether7
add bridge=LAN_Bridge comment=defconf interface=ether8
add bridge=Bridge_VLAN20_IoT interface=VLAN20_Eth5_IoT
add bridge=Bridge_VLAN30_Guest interface=VLAN30_Eth5_Guest
/ipv6 settings
set disable-ipv6=yes
add interface=LAN_Bridge list=LAN
add interface=ether2 list=WAN
add interface="WireGuard MikroTik" list=LAN
/interface wireguard peers
add allowed-address=172.22.0.2/32 interface="WireGuard MikroTik" public-key=\
"xxxxxxxxxxxxxxxxxxxxxxxxx"
add allowed-address=172.22.0.3/32 interface="WireGuard MikroTik" public-key=\
"xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx"
add address=10.0.0.1/24 comment="DHCP Standard" interface=LAN_Bridge network=\
10.0.0.0
add address=10.0.20.1/24 comment="VLAN IoT" interface=Bridge_VLAN20_IoT \
network=10.0.20.0
add address=10.0.30.1/24 comment="VLAN Guest" interface=Bridge_VLAN30_Guest \
network=10.0.30.0
add address=172.22.0.1/24 comment=WireGuard interface="WireGuard MikroTik" \
network=172.22.0.0
/ip dhcp-client
add dhcp-options=clientid,hostname interface=ether2 use-peer-dns=no
add address=10.0.0.0/24 dns-server=10.0.0.10 gateway=10.0.0.1
add address=10.0.20.0/24 dns-server=10.0.0.10 gateway=10.0.20.1
add address=10.0.30.0/24 dns-server=10.0.0.10 gateway=10.0.30.1
set allow-remote-requests=yes servers=10.0.0.10
/ip firewall address-list
add address=10.0.0.0/24 list=AllowWinBox
established,related,untracked
invalid
add action=accept chain=input comment=WireGuard dst-port=13231 protocol=udp
"defconf: accept to local loopback (for CAPsMAN)" disabled=yes \
dst-address=127.0.0.1
add action=add-src-to-address-list address-list=Blacklist \
address-list-timeout=1d chain=input dst-port=666 in-interface-list=WAN \
log=yes protocol=tcp
add action=drop chain=input comment="Drop connections from blacklist" \
in-interface-list=WAN src-address-list=Blacklist
in-interface-list=!LAN
add action=accept chain=input comment="Allow WinBox from LAN" dst-port=8291 \
in-interface-list=LAN log-prefix=winbox protocol=tcp src-address-list=\
AllowWinBox
connection-state=invalid
add action=accept chain=forward comment="Allow access to print from VLAN30" \
dst-address=10.0.0.3 src-address=10.0.30.0/24
"Allow access from HMHPhone to Phillips Hue" dst-address=10.0.0.4 \
src-address=10.0.20.249
"Allow DNS requests from VLAN20 --> 10.0.0.10" dst-address=10.0.0.10 \
dst-port=53 in-interface=Bridge_VLAN20_IoT out-interface=LAN_Bridge \
protocol=udp src-address=10.0.20.0/24
"Allow DNS requests from VLAN30 --> 10.0.0.10" dst-address=10.0.0.10 \
dst-port=53 in-interface=Bridge_VLAN30_Guest out-interface=LAN_Bridge \
protocol=udp src-address=10.0.30.0/24
add action=drop chain=forward comment="Drop external DNS requests" dst-port=\
53 log=yes log-prefix="DNS Drop" protocol=tcp src-address=!10.0.0.10
53 log=yes log-prefix="DNS Drop" protocol=udp src-address=!10.0.0.10
disabled=yes ipsec-policy=in,ipsec
disabled=yes ipsec-policy=out,ipsec
/ip firewall raw
add action=drop chain=prerouting comment=Russia log=yes log-prefix=IPRussia \
src-address-list=IPScope-Russia
add action=drop chain=prerouting comment=Belarus log=yes log-prefix=IPRussia \
src-address-list=IPScope-Belarus
add action=drop chain=prerouting comment=Turkey log=yes log-prefix=IPTurkey \
src-address-list=IPScope-Turkey
add action=drop chain=prerouting comment=Iran log=yes log-prefix=IPIran \
src-address-list=IPScope-Iran
add action=drop chain=prerouting comment=China log=yes log-prefix=IPChina \
src-address-list=IPScope-China
add action=drop chain=prerouting comment=Brazil log=yes log-prefix=IPBrazil \
src-address-list=IPScope-Brazil
add action=drop chain=prerouting comment=Iraq log=yes log-prefix=IPBrazil \
src-address-list=IPScope-Iraq
add action=drop chain=prerouting comment=Sudan log=yes log-prefix=IPSudan \
src-address-list=IPScope-Sudan
add action=drop chain=prerouting comment="South Sudan" log=yes log-prefix=\
IPSouthSudan src-address-list=IPScope-SouthSudan
/ip firewall service-port
set ftp disabled=yes
set tftp disabled=yes
set h323 disabled=yes
set sip disabled=yes
set pptp disabled=yes
add disabled=no dst-address=10.0.0.10 gateway=10.0.0.6 routing-table=main \
suppress-hw-offload=no
/ip service
set telnet disabled=yes
set ssh disabled=yes
set www-ssl disabled=no
set api disabled=yes
set api-ssl disabled=yes
/system clock
set time-zone-name=Europe/Copenhagen
/system identity
set name=
/system ntp client
set enabled=yes
/system ntp client servers
add address=time.google.com
/system package update
set channel=testing
/tool mac-server
/tool mac-server mac-winbox
