Hai Friend new packages is come...and this changelog that version for..
What's new in 2.9.44:
*) fixed support for MTB-134 / Portwell EZIO LCD display;
*) fixed bug - user-manager did not send upload/download limit gigawords
to hotspot server (value was limited to 4.2 GB);
*) fixed bug - hotspot login could fail with "failed to grant access"
under some specific configurations;
*) routing-test - fixed bug introduced in 2.9.43. connected routes could show
wrong interface;
*) routing-test - fixed multipath route displaying
(only one address were displayed for all nexthops);
*) fixed bug - DHCP server did not parse Relay-Agent-Info option 82;
*) fixed PSD matcher in firewall;
*) made Torch to not exlcude non TCP & UDP traffic if no specific port was provided;
*) fixed bug - telephony could crash on incoming ISDN call;
*) fixed bug in ospf - nbma network sometimes lost all ospf routes after
peer flap;
*) PPP will use private address automaticly if remote end has not provided one;
*) added initial calea support
*) user manager - 3-byte char (UTF-8) bugfix;
