I’m using routerBOARD 750G with routerOS 4.17. Is there any difference between “system reset” command and hardware reset button? Thanks.
Reset command has parameters like no-defaults=yes/no and run-after-reset. While reset button can also be used to initiate etherboot.
That’s nice, thank you. But what if I use “system reset” command without any parameter? I think this will be identical to press and hold Reset button.
Dear,
If you want to reset all configuration RB , please use from :
new terminal – > setup – > and type R and select y to reset all configuration rb and return to default .
If you want to boot the RB please use reset button coz the reset button just boot .
yes
