Are there any limitation in number of interface lists ?
Hello there!
I have Cloud Server (CHR RouterOS 7.2.3),
I have 239 interface lists, when I try to add another one my server appears with an error, interrupted, and suddenly reboots.
is there any limitation in the number of interface lists?
How many interfaces do you have since you need more than 200 interface lists?
Why do you need a list of interfaces for each individual interface, with only one interface inside?
I use them for a Dynamic interface with VRF for each Profile
I use them for a Dynamic interface with VRF for each Profile...
PS no need to make two post about the same. You can do many quote in one post.
Still does not understand what is your goal is. Is the some in production, or just for test?
Make a design drawing.
Regardless of what the goal is, and even if it may be possibly wrong, adding too many lists shouldn’t cause reboot (and yes, my quick test says that it does happen). That’s clearly a bug. I don’t know if there’s supposed to be some limit or not, it doesn’t seem documented anywhere. So if you need it, contact support and let them clarify how it should be and do something with it.
I’m sorry
this is a VPN server to bridge multiple sites over SSTP connection, every interface list with many VPN client interfaces for one VRF list to be isolated from other customers
I don’t know if this is the best way …
thanks a lot
I mean, isn’t it obvious? The command for rebooting router is /system/reboot. If anything else (not counting update) reboots router, it can’t be right. :slight_smile:
But it doesn’t mean that you’ll get good news from support, it’s possible that there’s supposed to be a limit and they just forgot to add a check and error message. Ask them and you’ll see.
Is this some you have in production, or some you like to setup? Can you post the config?
Same Problem here. I was limited without an error by 244 Interface Lists.. This seems to be a bug.
Any Fixes here since 2022 ?
