Hello to the community,
I have a hEX RB750Gr3 with RouterOS v6.39.1 in an enterprise environment, for 50-60 concurrent mobile devices, with 3 VDSL load-balanced internet circuits for breaking out. For segregation reasons I have seperated the LAN connection to 2 VLANs. One for management purposes (VLAN190, which is routable to the internal enterprise network), and one for the actual users (VLAN667, which is a non-routed VLAN for security reasons). I have also a VRRP interface under VLAN667 because I have an identical secondary hEX in case the primary fails. The thing is that the users listed in the ARP table are either labeled with the eth1-Vlan667 interface or vrrp1 interface, and I don’t know why.
All users are being assigned addresses from the same DHCP server and can’t explain this behavior.
Below is a part of the configuration and below that is the ARP table:
set [ find default-name=ether1 ] comment=LAN
set [ find default-name=ether2 ] comment=VDSL1_2103251803
set [ find default-name=ether3 ] comment=VDSL2_2103225424
set [ find default-name=ether4 ] comment=VDSL3_2103253015
set [ find default-name=ether5 ] disabled=yes
/interface vlan
add interface=ether1 name=eth1-vlan190 vlan-id=190
add interface=ether1 name=eth1-vlan667 vlan-id=667
/interface vrrp
add interface=eth1-vlan667 interval=3s name=vrrp1 on-backup="ip dhcp-server disable 0\
\n" on-master="ip dhcp-server enable 0\
\n\
\n" priority=254 vrid=10
add address=10.19.0.101/24 comment=mngmnt interface=eth1-vlan190 network=10.19.0.0
add address=192.168.0.2/23 comment=LAN_clients interface=eth1-vlan667 network=192.168.0.0
add address=192.168.0.1 comment=VRRP interface=vrrp1 network=192.168.0.1
add address=192.168.2.2/24 comment=WAN_VDSL1 interface=ether2 network=192.168.2.0
add address=192.168.3.2/24 comment=WAN_VDSL2 interface=ether3 network=192.168.3.0
add address=192.168.4.2/24 comment=WAN_VDSL3 interface=ether4 network=192.168.4.0
add address-pool=pool1 disabled=no interface=eth1-vlan667 lease-time=8h name=server1
add address=192.168.0.0/23 dns-server=8.8.8.8 gateway=192.168.0.1 netmask=23
add name=pool1 next-pool=pool1 ranges=192.168.0.11-192.168.0.255,192.168.1.11-192.168.1.100
[admin@MikroTik1] /ip arp> print
Flags: X - disabled, I - invalid, H - DHCP, D - dynamic, P - published, C - complete
# ADDRESS MAC-ADDRESS INTERFACE
0 DC 10.19.0.1 00:00:0C:07:AC:13 eth1-vlan190
1 DC 192.168.3.1 28:FF:3E:04:D7:FC ether3
2 DC 192.168.0.19 78:4F:43:6E:F5:0D eth1-vlan667
3 DC 192.168.0.39 90:18:7C:E8:5C:EE eth1-vlan667
4 DC 192.168.0.77 C0:D0:12:B9:36:77 eth1-vlan667
5 DC 192.168.0.78 2C:59:8A:6B:F5:25 eth1-vlan667
6 DC 192.168.0.46 FC:F8:AE:A6:7B:60 eth1-vlan667
7 DC 192.168.0.120 8C:F5:A3:DB:F2:C2 eth1-vlan667
8 DC 192.168.0.51 98:01:A7:15:48:AC eth1-vlan667
9 DC 192.168.0.16 D0:87:E2:28:F6:5A eth1-vlan667
10 DC 192.168.0.17 10:3B:59:1A:3B:50 eth1-vlan667
11 DC 192.168.0.55 78:D7:5F:CA:38:47 eth1-vlan667
12 DC 192.168.0.56 B8:53:AC:5E:9E:0C eth1-vlan667
13 DC 192.168.0.21 00:0A:F5:C7:71:24 eth1-vlan667
14 DC 192.168.0.23 04:15:52:9E:51:8A eth1-vlan667
15 DC 192.168.0.27 84:BE:52:B8:90:D6 eth1-vlan667
16 DC 192.168.0.101 DC:37:14:70:08:B1 eth1-vlan667
17 DC 192.168.0.102 F0:99:BF:7D:60:00 eth1-vlan667
18 DC 192.168.0.104 7C:B0:C2:27:A9:2F eth1-vlan667
19 DC 192.168.0.105 2C:0E:3D:44:15:AF eth1-vlan667
20 DC 192.168.0.106 40:B8:9A:4B:86:BF eth1-vlan667
21 DC 192.168.0.70 8C:F5:A3:21:49:5A eth1-vlan667
22 DC 192.168.0.37 D0:C5:F3:60:CC:48 eth1-vlan667
23 DC 192.168.0.41 B8:53:AC:0A:2B:FD eth1-vlan667
24 DC 192.168.0.194 20:3C:AE:E3:4A:4B eth1-vlan667
25 DC 192.168.0.50 00:EB:2D:A2:FE:CB eth1-vlan667
26 DC 192.168.0.128 68:FB:7E:DB:60:05 eth1-vlan667
27 DC 192.168.0.108 30:07:4D:6F:FB:C1 eth1-vlan667
28 DC 192.168.0.112 24:F0:94:6B:40:8F eth1-vlan667
29 DC 192.168.0.40 A8:5B:78:86:4B:2E eth1-vlan667
30 DC 192.168.0.114 96:8F:A5:88:AD:7B eth1-vlan667
31 DC 192.168.0.115 A4:B8:05:CD:45:FB eth1-vlan667
32 DC 192.168.0.116 C0:D0:12:A2:FE:97 eth1-vlan667
33 DC 192.168.0.117 60:D9:C7:AA:AF:5B eth1-vlan667
34 DC 192.168.0.122 48:4B:AA:46:92:86 eth1-vlan667
35 DC 192.168.0.123 34:FC:EF:A6:8A:2A eth1-vlan667
36 DC 192.168.0.14 20:6E:9C:74:5D:A8 eth1-vlan667
37 DC 192.168.4.1 78:C1:A7:3B:5B:14 ether4
38 DC 192.168.1.28 00:03:AB:BD:65:CA eth1-vlan667
39 DC 192.168.0.97 44:85:00:EF:8B:E3 eth1-vlan667
40 DC 192.168.0.136 8C:C5:E1:1A:09:BF eth1-vlan667
41 DC 192.168.0.29 B8:53:AC:08:80:FD eth1-vlan667
42 DC 192.168.2.1 D4:21:22:4A:3E:B0 ether2
43 DC 192.168.0.31 70:F0:87:D2:C7:F8 eth1-vlan667
44 DC 192.168.0.68 24:A0:74:54:8C:D6 eth1-vlan667
45 DC 192.168.0.34 48:4B:AA:50:7B:7B eth1-vlan667
46 DC 192.168.0.145 60:AF:6D:C0:22:4E eth1-vlan667
47 DC 192.168.0.109 84:89:AD:43:A5:A0 eth1-vlan667
48 DC 192.168.0.103 48:74:6E:5A:9B:E6 eth1-vlan667
49 DC 192.168.0.65 58:40:4E:7A:82:46 eth1-vlan667
50 DC 192.168.0.97 44:85:00:EF:8B:E3 vrrp1
51 DC 192.168.0.41 B8:53:AC:0A:2B:FD vrrp1
52 DC 192.168.0.128 68:FB:7E:DB:60:05 vrrp1
53 DC 192.168.0.56 B8:53:AC:5E:9E:0C vrrp1
54 DC 192.168.0.27 84:BE:52:B8:90:D6 vrrp1
55 DC 192.168.0.106 40:B8:9A:4B:86:BF vrrp1
56 DC 192.168.0.40 A8:5B:78:86:4B:2E vrrp1
57 DC 192.168.0.103 48:74:6E:5A:9B:E6 vrrp1
58 DC 192.168.0.68 24:A0:74:54:8C:D6 vrrp1
59 DC 192.168.0.101 DC:37:14:70:08:B1 vrrp1
60 DC 192.168.0.112 24:F0:94:6B:40:8F vrrp1
61 DC 192.168.0.31 70:F0:87:D2:C7:F8 vrrp1
62 DC 192.168.0.117 60:D9:C7:AA:AF:5B vrrp1
63 DC 192.168.0.23 04:15:52:9E:51:8A vrrp1
64 DC 192.168.0.51 98:01:A7:15:48:AC vrrp1
65 DC 192.168.0.102 F0:99:BF:7D:60:00 vrrp1
66 DC 192.168.0.77 C0:D0:12:B9:36:77 vrrp1
67 DC 192.168.0.78 2C:59:8A:6B:F5:25 vrrp1
68 DC 192.168.0.37 D0:C5:F3:60:CC:48 vrrp1
69 DC 192.168.0.104 7C:B0:C2:27:A9:2F vrrp1
70 DC 192.168.0.114 96:8F:A5:88:AD:7B vrrp1
