I am working on a setup that involves up to 50 static ARP entries with an interface set to reply-only mode.
Will this number of entries result in any significant slow down of ARP look ups?
Thanks,
Guy
Thanks,
Guy
hello
not really tested, but as the arp table works like a cache it should only speed up arp requests, otherwise the request has to be send out to the media. (btw. i have read about a 1024 entries limit)
Ah, yes, I hadn’t thought of it that way. I am eliminating the dynamic add/remove from the table so there is one less process.
Thanks,
Guy
