Hi.
I would like to do my clients on my AP can’t change their IP addresses, like on Ethernet interfaces. But if I enable the ARP reply-only feature, they can communicate with each other still freely. I don’t want to disable their communication, only make traffic shaping rules fot it, but because they are IP based, like firewall too, I need to force clients the same IP addresses.
I think the only way to do that is the ARP lock, but it doesn’t work. If I set it to reply-only, they can’t ping the AP, but they still can communicate with each other.
Please help.
Thank you.
