ARP List Filter wildcards?
Are there any wildcards I can put in the ARP list filter, for instance 192.168.3.* so it’ll just show the list of those IP addresses?
What if you search 10.81.37 or 192.168.3 if you seek that?
I was using both 192.168.3.* & 10.81.37.* for examples. I just want a list of all of one specific IP range i’m working in since there are multiple blocks assigned to that router.
Oh, I see what you are saying. I tried it and the list is still bouncing around.
My ARP list was always updating and i’d loose track of which IP I would be double checking. I was hoping you might be on to something and prevent it from refreshing but since typing the response, it still updated and moved the list around.
What if you sort on MAC or interface. Also you have the find box in the right top corner with which you can highlight the address you want to track visually.
So, I may have jumped the gun on your first response. I am currently using the find box and I just cruised through a small block checking stuff out and the list stayed in tack, didn’t move around and I didn’t throw my hands up and sigh really loud. So with that being said, i’m going to try a couple more blocks and even another tower router just to see if it works this way and I will let you know. Thanks!
Youre welcome and Mikrotik gave us great tools to get insight.
