I'm having an issue with ARP not expiring -
User A (mac-address aa:aa:aa:aa:aa:aa) connects and gets a lease of 5 minutes per radius from Pool A (IP 172.17.46.35).
User then registers to gain access to network.
Client renews lease (due to 5min lease time) and gets new lease from Pool B per radius (IP X.X.X.X).
New user connects and gets assigned 172.17.46.35 (mac-address bb:bb:bb:bb:bb:bb).
This is what the arp and dhcp lease tables look like at this point -
[admin@router] > ip arp pri where mac-address =aa:aa:aa:aa:aa:aa
Flags: X - disabled, I - invalid, H - DHCP, D - dynamic, P - published
ADDRESS MAC-ADDRESS INTERFACE
0 D 172.17.46.35 aa:aa:aa:aa:aa:aa TENANT-ACCESS
1 D X.X.X.X aa:aa:aa:aa:aa:aa TENANT-ACCESS
[admin@router] > ip dhcp-server lease pri where active-address =172.17.46.35
Flags: X - disabled, R - radius, D - dynamic, B - blocked
ADDRESS MAC-ADDRESS
0 R PoolA bb:bb:bb:bb:bb:bb
The stale entry from the first users original lease persists in the table. It will not clear until manually removed. Time doesn't appear to make a difference, it will set there for hours if not manually cleared.
ROS 6.11
From ip settings -
arp-timeout: 30s
dhcp-server address pool is not set to static-only
I have this behavior happening on multiple routers.
Any direction is appreciated.
Thanks,
