ARP reply on the same interface
Hi everybody,
I have connected a CCR1016-12g mikrotik to a L2 GPON network (interface vlan 5 on eth4 with IP address: 192.168.5.1/24).
In the other side of the GPON network I have two routers 750GL (interface vlan 5 too, IP address 192.168.5.11 and 192.168.5.19). Routers 750GL have no direct connection so communication between them must pass through CCR1016 interface.
Mikrotik CCR1016 has learnt properly MAC addresses from routers 750GL and I can do a ping between one router 750GL and the CCR1016 but it is not possible to do a ping between both routers 750GL.
For example, ARP messages are sent from interface 192.168.5.11 asking about 192.168.5.19. These ARP messages are received by CCR1016 router interface but they have no response.
Any ideas? Thanks.
This is correct, they should be answered by the 750GL router #2.
ARP assumes that in a subnet everyone is able to receive eachothers broadcasts.
Thanks. So it is not possible to do what I want to, I guess.
If you only need this between one specific set of clients, then you can do a work-around where you add a static ARP entry on each client with the CCR’s MAC address instead of the real MAC address of the “neighbor” 750G.
So in your example, in the left-side 750GL:
/ip arp add mac-address=MAC:OF:CCR interface=vlan5 address=192.168.5.19
and on the right-side 750GL:
/ip arp add mac-address=MAC:OF:CCR interface=vlan5 address=192.168.5.11
This will work, but is a bit sloppy because the CCR is going to be sending ICMP redirect messages like crazy. The 750GL routers won’t do anything different due to the ICMP redirects because they think they’re already talking directly to the “neighbor”
This is of course a sloppy work-around. A more scalable solution is to use a dedicated per-customer logical interface and to configure each customer interface with arp=proxy-arp and a /32 address assignment. This way, whenever a customer device sends an ARP for a neighboring customer device’s IP, it will receive the MAC address of the CCR and thus direct all packets to the CCR for forwarding. The CCR will see each customer as a different interface, so it won’t send ICMP redirects.
The way to configure the IP addresses on the CCR is as a /32 for each customer interface:
/ip address add interface=customerX address=192.168.5.1/32 network=192.168.5.X
Interface customerX would be a vlan interface on the physical interface that leads to the GPON concentrator. Each customer would therefore require their own dedicated VLAN tag.
The way to scale this beyond just ~4000 vlans would be to use q-in-q between the CCR and the GPON concentrator(s)
(i.e. use s-tag / c-tag configuration)
So on the CCR, you’d have:
ether1
-vlan10 (id=10) ← s-tag
    • customerA (id=101) ← c-tag
    • customerB (id=102) ← c-tag
      -vlan20 (id=20) ← s-tag
    • customerC (id=101) ← c-tag
Note that customer C uses inner vlan 101 just like customer A does, but a different outer VLAN.
Ideally, the GPON system lets you provision the ONTs with the s-tag/c-tag information so that the customer router behind the ONT doesn’t need any vlan configuration at all. You build the ONT profile and CCR interface with the correct tags, and you’re done. The S-tag would basically be unique for each OLT in your network, or for each shelf of OLTs.
I wish that ROS had a certain feature that Cisco has - namely DHCP relay that adds a /32 route to the interface based on replies from the DHCP server. This way, you wouldn’t need to actually configure the IP directly on the CCR - you would just configure DHCP relay and then when the server assigns an IP to a customer on any given interface, the CCR would just add the IP for the lifetime of the lease. This would further reduce administrative overhead.
Another option is to use PPPoE between the CCR and the client routers.
Hi ZeroByte,
Thank you very much for your answers. The best solution for me is PPPoE connection due to the number of client routers I’m going to deploy.
