hi all,
I want to thank you for this forum,
i want to ask how to stop programs like arp spoofers and netcut on my network using mikrotik server
The easy solution with mikrotik will be creating a PPPOE server and serving ur clients with ppp username and password, this way you not have to sit and monitor the garbage on ur LAN coz simply there will be nothing to sniff, you can also uncheck TCP/IP on Client XP PCs,this way u’ll have a totally clean lan.Try it and let me now if u need added security.
Thanks my firend,
But i want you to tell me How to do that on mirotik…
